BPI-AI
Revision as of 04:08, 20 February 2021 by Sinovoip (talk | contribs) (Hardware spec)
BPI-AI Kendryte K210 RISC-V
BPI-Bit with ESP32 design
BPI-K210 RISC-V AIoT board
BPI-AI(also name Web:AI for Webduino) design with K210 RISC-V chip design.An integrated artificial intelligence SOC chip solution that can accommodate neural network models, using a new risc-v instruction set for the field of artificial intelligence and edge computing. The main target market is the AIoT and STEAM education market,it support screen and camera. so easy to do many AI application, cowork with Webduino team. and support Webduino blockly for STEAM education.
Type Applications
  • AI for Edge Computing
  • Smart Building
  • Medical equipment
  • Automation & Process Control
  • Robot
  • IoT applications
  • STEAM education
  • 8MB On-Chip SRAM 128Kbit One-Time Programmable Memory (OTP) ,Read Only Memory (ROM)
  • DMA
  • Camera and screen interface
  • WiFI (ESP8285)
  • JTAG, OpenOCD support
About Kendryte K210 chip
BPI-AI hardware
Hardware Interface
HardWare Specification of Banana pi BPI-AI (WEB:AI)
CPU Kendryte K210 64-bit RISC-V CPU Dual-Core, up to 400MHz,with neural processing unit (NPU)
Memory SPI flash and The accelerator has its own memory, with 6MB of static RAM given over to the dual-core CPU and a further 2MB for the NPU coprocessor.
camera 5 million pixel cameras
WIFI ESP8285 wifi module support 802.11.b/g/n
Audio Output(s) Built-in MEMS microphone supports 3W speaker output
LCD Screen 8bit MCU 2.3 LCD,DPI 320x240
Socket Compatible with BPI: BIT Micro:bit Goldfinger,TF card ,Speaker,lithium battery interface
Development environment Arduino IDE, MaixPy IDE ,Webduino
Switches Reset, A/B key
Power Source 5volt@2A via Micro USB ,lithium battery interface(3.7-4.2V)
Size & Weight 51.6mm×67mm, 58g
BPI-AI software
Source code on github
Support
