BPI-M5介绍
Banana Pi BPI-M5
Amlogic S905X3 Processor
Banana Pi BPI-M5是新一代单板计算机设计,采用Amlogic S905X3四核Cortex-A55 (2.0xxGHz)处理器。MP2 GPU(650Mhz)。支持4GB LPDDR4和16G eMMC板载存储。它有4个USB 3.0端口,1个千兆网口。
905X3是晶晨半导体旗下最新的8K智能家庭影音芯片,采用四颗64位ARM A55架构 CPU芯片,集成G31图形处理器,支持8K视频解码和8K视频输出,运行开放的安卓9.0系统和Linux系统。
- Mali-G31 GPU图形处理器
- 4GB LPDDR4内存
- 16GB eMMC 板载存储.
- 4 USB 3.0 端口
- 1 GbE 千兆网口
- HDMI 输出
开发快速上手
硬件接口
| 香蕉派BPI-M5 硬件规格表
| CPU |
Amlogic S905X3 Quad-Core Cortex-A55 (2.0xxGHz)
| GPU |
Mali-G31 MP2 GPU with 4 x Execution Engines (650Mhz)
| Memory |
4 GB LPDDR4
| Storage |
MicroSD slot with support for up to 256GB expansion and 16G eMMC flash with support for up to 64GB
| Network |
10/100/1000 Mbit/s Ethernet
| Video Output(s) |
1 x HDMI 2.0 (up to 4K@60Hz with HDR, CEC, EDID)
| Audio Output(s) |
3.5mm jack and 1 x HDMI digital output
| USB ports |
USB 3.0 PORT (x4)
| GPIO |
40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND). GPIO pins can be used for UART, I2C, SPI or PWM
| Switches |
Reset, Power and U-boot
| LED |
Power Status and Activity status
| Power Source |
5 volt @3A via Micro USB (TYPE C)
| Size & Weight |
92x60mm, 48g
| OS |
Android and Linux
香蕉派BPI-M5 与 Odroid C4 和 Raspberry Pi 4硬件规格比较表
| BPI-M5 VS Odroid C4 VS RPI 4
Banana Pi BPI-M5 |
Odroid C4 |
Raspberry Pi 4
| Processor |
Amlogic S905X3 Quad-Core Cortex-A55 ARMv8.2-A 64-bit 1.5GHz |
Broadcom BCM2711, Quad core Cortex-A72 (ARM v8) 64-bit SoC @ 1.5GHz
| GPU |
Mali-G31 MP2 GPU |
Mali-G31 MP2 GPU |
Broadcom VideoCore VI
| RAM |
4GB LPDDR4 |
DDR4 memory (4GiB) |
2GB, 4GB or 8GB LPDDR4-3200 SDRAM
| Storage |
micro SD card slot & 16GB eMMC flash on board |
micro SD card slot , non EMMC |
micro SD card slot, non EMMC
| Network |
GbE ,Optional WiFi USB dongle |
GbE |
GbE, 2.4 GHz and 5.0 GHz IEEE 802.11ac wireless, Bluetooth 5.0, BLE
| Video Output |
1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID) |
2 × micro-HDMI 2.0
| Audio Output |
3.5mm jack and 1 x HDMI digital output |
N/A |
3.5 mm analogue audio-video jack
| DSI |
N/A |
N/A |
2-lane MIPI DSI display port
| CSI |
N/A |
N/A |
2-lane MIPI CSI camera port
| USB |
USB 3.0 x 4 TYPE C |
USB 3.0 x 4, 1 x Micro USB 2.0 port (OTG) |
2 USB 3.0 ports; 2 USB 2.0 ports;
| Power |
5 volt @3A via Micro USB (TYPE C) |
1 x DC power jack (Outer diameter : 5.5mm, inner diameter : 2.1mm) |
5V DC via USB-C connector (minimum 3A*)
| IR |
Yes |
Yes |
N/A
| GPIO |
40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND). |
40 x GPIO pins |
40-pin GPIO header, populated
| Button |
Reset, user and U-boot |
N/A |
N/A |
| LED |
Power Status and Activity status |
| Dimensions & weight |
85x56mm, 48g |
88 mm × 58 mm × 19.5 mm, 46 g
| Linux Support |
Linux & Android |
Linux & Android |
Linux & Android
GPIO PIN 定义
BPI-M5 40PIN GPIO 定义 (CON2)
| GPIO Pin Name |
Default Function |
Function2 |
Function3
| CON1-P01 |
VCC-3V3 |
| CON1-P02 |
VCC5V |
| CON1-P03 |
GPIOX_17 |
I2C_M2_SDA |
| CON1-P04 |
VCC5V |
| CON1-P05 |
GPIOX_18 |
I2C_M2_SCL |
| CON1-P06 |
GND |
| CON1-P07 |
GPIOX_5 SDIO_CMD |
| CON1-P08 |
GPIOX_12 |
UART_A_TX |
| CON1-P09 |
GND |
| CON1-P10 |
GPIOX_13 |
UART_A_RX |
| CON1-P11 |
GPIOX_3 SDIO_D3 |
| CON1-P12 |
GPIOAO_8 |
TDMB_SCLK |
| CON1-P13 |
GPIOX_4 SDIO_CLK |
| CON1-P14 |
GND |
| CON1-P15 |
GPIOX_7 PWM_F |
| CON1-P16 |
GPIOX_0 SDIO_D0 |
| CON1-P17 |
VCC-3V3 |
| CON1-P18 |
GPIOX_1 SDIO_D1 |
| CON1-P19 |
GPIOX_8 PCM_DIN |
| CON1-P20 |
GND |
| CON1-P21 |
GPIOX_9 PCM_DOUT |
| CON1-P22 |
GPIOX_2 SDIO_D2 |
| CON1-P23 |
GPIOX_11 |
PCM_CLK |
| CON1-P24 |
GPIOX_10 |
PCM_SYNC |
| CON1-P25 |
GND |
| CON1-P26 |
GPIOX_16 |
PWM_E |
| CON1-P27 |
GPIOA_14 |
I2C_M3_SDA |
| CON1-P28 |
GPIOA_15 |
I2C_M3_SCL |
| CON1-P29 |
GPIOX_14 |
UART_A_CTS |
| CON1-P30 |
GND |
| CON1-P31 |
GPIOX_15 |
UART_A_RTS |
| CON1-P32 |
GPIOX_19 |
PWM_B |
| CON1-P33 |
GPIOX_6 PWM_A |
| CON1-P34 |
GND |
| CON1-P35 |
GPIOAO_7 |
TDMB_FS |
| CON1-P36 |
GPIOH_5 SPDIF_IN |
| CON1-P37 |
GPIOAO_7 |
I2S_MCLK |
| CON1-P38 |
GPIOAO_10 |
TDMB_DIN |
SPDIF_OUT
| CON1-P39 |
GND |
| CON1-P40 |
GPIOAO_4 |
TDMB_DOUT |
BPI-M5调试串口定义 UART(CON1)
| CON2-P1 |
GND
| CON2-P2 |
UART0-RX
| CON2-P3 |
UART0-TX
documents
