Banana Pi BPI-M5
Revision as of 05:06, 11 December 2020 by Dangku (talk | contribs) (→Linux)
Banana Pi BPI-M5
Amlogic S905X3 Processor
BPI-M5 case design
Banana Pi BPI-M5 is a new generation single board computer design , use Amlogic S905X3 Quad-Core Cortex-A55 (2.0xxGHz) Processor. Mali-G31 MP2 GPU with 4 x Execution Engines (650Mhz). support 4GB LPDDR4 and 16G eMMC flash. it have 4 USB 3.0 port,1GbE LAN port.
  • Amlogic S905X3 Quad-Core Cortex-A55 (2.0xxGHz) Processor
  • Mali-G31 GPU
  • 4GB LPDDR4
  • 16GB eMMC flash on board.
  • 4 USB 3.0 port
  • 1 GbE LAN por
  • HDMI output
Memory 4 GB LPDDR4
USB ports USB 3.0 PORT (x4)
Size & Weight 92x60mm, 48g
OS Android and Linux
BPI-M5 VS Odroid C4 VS Raspberry Pi 4
BPI-M5 VS Odroid C4 VS RPI 4
Banana Pi BPI-M5 Odroid C4 Raspberry Pi 4
Processor Amlogic S905X3 Quad-Core Cortex-A55 ARMv8.2-A 64-bit 1.5GHz Amlogic S905X3 Quad-Core Cortex-A55 ARMv8.2-A 64-bit 1.5GHz Broadcom BCM2711, Quad core Cortex-A72 (ARM v8) 64-bit SoC @ 1.5GHz
GPU Mali-G31 MP2 GPU Mali-G31 MP2 GPU Broadcom VideoCore VI
RAM 4GB LPDDR4 DDR4 4GiB with 32-bit bus width 2GB, 4GB or 8GB LPDDR4-3200 SDRAM
Storage micro SD card slot & 16GB eMMC flash on board micro SD card slot , eMMC connector for option micro SD card slot, non EMMC
Network GbE ,Optional WiFi USB dongle GbE GbE, 2.4 GHz and 5.0 GHz IEEE 802.11ac wireless, Bluetooth 5.0, BLE
Video Output 1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID) 1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID) 2 × micro-HDMI 2.0
Audio Output 3.5mm jack and 1 x HDMI digital output Optional SPDIF optical output 3.5 mm analogue audio-video jack
DSI N/A N/A 2-lane MIPI DSI display port
CSI N/A N/A 2-lane MIPI CSI camera port
USB USB 3.0 x 4 TYPE C USB 3.0 x 4, 1 x Micro USB 2.0 port (OTG) 2 USB 3.0 ports; 2 USB 2.0 ports;
Power 5 volt @3A via Micro USB (TYPE C) 1 x DC power jack (Outer diameter : 5.5mm, inner diameter : 2.1mm) 5V DC via USB-C connector (minimum 3A*)
IR Yes Yes N/A
GPIO 40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND). 40 x GPIO pins 40-pin GPIO header, populated
Button Reset, user and U-boot N/A N/A
LED Power Status and Activity status Power Status and Activity status Power Status and Activity status
Dimensions & weight 85x56mm, 48g 85mm x 56mm x 1.0mm 59g 88 mm × 58 mm × 19.5 mm, 46 g
Linux Support Linux & Android Linux & Android Linux & Android
android source code: https://github.com/BPI-SINOVOIP/BPI-S905X3-Android9
Linux BSP code: https://github.com/BPI-SINOVOIP/BPI-M5-bsp
documents
  • 2020-12-11 release, Android 9.0 with kernel 4.9.113
Download: 2020-12-11-bpi-m5-android-9-emmc.zip
MD5: 962325face002250ad4254f7c4625f30
How to flash Android Image
  • 2020-12-11 release, Ubuntu Mate Desktop 18.04 with kernel 4.9.236
Download: 2020-12-10-ubuntu-18.04-mate-desktop-bpi-m5-aarch64-sd-emmc.img.zip
MD5: 28e4f4e130949fa8257297303fc81139
How to flash Linux Image
CoreELEC
