Getting Started with M5/M2Pro
Revision as of 09:11, 9 December 2020 by Dangku (talk | contribs) (Prepare)
Banana Pi BPI-M5
Amlogic S905X3 Processor
  • Mali-G31 MP2 GPU @ 650Mhz
  • System Memory – 4GB LPDDR4
  • Weight – 48grams
3. The SOC rom first boot sequence is emmc, so board can't bootup from SDcard if the emmc is bootable with any image flashed, more info about the image boot sequence please refer to board boot flow.
4.
2. Download the AML Burn Card Maker tool for create a bootable sdcard to flash android image to emmc, only support windows.
3. Download the latest android image.
2. Make sure bootable EMMC is formatted from sector 0 if you want bootup from SDcard, and make sure bootable SDcard is formatted if you want bootup from EMMC(because uboot read bootscript file from mmc:1 first, which is SDcard dev, This is used for quickly SDcard bootup debug or flash image to EMMC while EMMC is bootable).
3. Install bpi-tools on your Linux PC. If you can't access this URL or any other install problem, please go to bpi-tools source repo, download and install this tools manually.
 $ apt-get install pv
4. Download Linux latest image.
5. Default login: pi/bananapi or root/bananapi
Install Image to SDcard
2. Install bpi image with Etcher on Windows, Linux and MacOS.
Install Image to EMMC
1. Prepare
