| Banana Pi Single board computer Comparison
| module |
Banana Pi BPI-M1 |
Banana Pi BPI-M1+ |
Banana Pi BPI-M2+ |
Banana Pi BPI-ZERO |
Banana Pi BPI-P2 Zero |
Banana Pi BPI-M2M |
Banana Pi BPI-M2 Berry |
Banana Pi BPI-M2U |
Banana Pi BPI-M3 |
Banana Pi BPI-M64 |
Banana Pi BPI-M4 |
Banana Pi BPI-M5 |
Banana Pi BPI-S64 Core |
Banana Pi BPI-F2 |
| photo |
Allwinner A20 |
Allwnner A20 |
Awinner H3/H2+/H5 |
Allwinner H2+ same size as RPI Zero W |
Allwinner H2+ PoE |
Allwinner R16/A33 |
Allwinner R40/V40 same size as RPI 3 |
Allwinner R40/V40 |
Allwinner A83T |
Allwinner A64 |
Realtek RTD1395 |
Amlogic S905x3 |
BPI-S64 Core Actions S700 |
BPI-F2 with freescale IMX6 |
in progress |
| CPU |
A20,32 Bit Cortex™-A7 Dual-Core |
H3,32 Bit Cortex™-A7 Quad-Core |
H2+,32 Bit Cortex™-A7 Quad-Core |
A33/R16,32 Bit Cortex™-A7 Quad-Core |
R40/V40,32 Bit Cortex™-A7 Quad-Core |
A83T,32 Bit Cortex™-A7 Octa-Core |
A64, 64 Bit Cortex A53 Quad Core |
Realtek RTD1395 ARM Cortex-A53 Quad-Core 64 Bit |
Amlogic S905X3 Quad-Core Cortex-A55 (2.0xxGHz) 64 bit |
Actions SOC S700,ARM Cortex-A53 Quad-Core CPU |
freescale IMX6 ARM Cortex-A9 MPCore 4xCPU processor(with TrustZone) |
| GPU |
ARM® Mali400MP2 |
ARM® Mali400MP2 |
ARM® Mali400MP2 |
ARM® Mali400MP2 |
ARM® Mali400MP2 |
ARM® Mali400MP2 |
ARM® Mali400MP2 |
ARM® Mali400MP2 |
PowerVR SGX544MP2 GPU |
ARM® Mali400MP2 |
Mali 470 MP4 GPU |
Mali-G31 MP2 GPU with 4 x Execution Engines (650Mhz) |
Mali450 MP4 GPU ,OpenGL ES2.0/1.1 OpenVG 1.1 EGL 1.5 |
OpenGL ES 2.0 3D graphics accelerator with forshaders,2D graphics accelerator,and didicated OpenVG 1.1 accelerator |
| Memory \(SDRAM\) |
1G (shared with GPU) |
512M(shared with GPU) |
512(shared with GPU) |
2G (shared with GPU) |
1G DDR4(option 2G) |
4GB LPDDR4 |
2GB LPDDR3 |
2GB LPDDR3 |
| Onboard Storage |
SD (Max. 32GB)/MMC card slot SATA 2.0 port via SOC |
MicroSD(TF) card /MMC card slot eMMC 8GB |
MicroSD(TF) card /MMC card slot |
MicroSD(TF) card /MMC card slot eMMC 8GB(option) |
MicroSD (TF) card / MMC card slot eMMC 8GB SATA 2.0 port via USB |
MicroSD (TF) card / MMC card slot eMMC 8GB |
MicroSD(TF) card /MMC card slot SATA 2.0 port via SOC |
MicroSD(TF) card /MMC card slot SATA 2.0 port via SOC eMMC 8GB |
MicroSD (TF) card / MMC card slot ,eMMC 8GB,PCIE interface |
MicroSD (TF) card / MMC card slot ,eMMC 16GB |
eMMC8GB |
MicroSD (TF) card / MMC card slot ,eMMC 8GB,SATA interface |
| Network |
10/100/1000 Ethernet |
NOPE |
100M Ethernet |
NOPE |
10/100 Ethernet |
10/100/1000 Mbit/s Ethernet |
Kit:10/100/1000 Ethernet |
| Onboard WIFI &BT |
NOPE |
802.11b/g/n |
802.11b/g/n & BT4.0 |
RTL8821 module withWi-Fi 802.11 b/g/n/AC |
N/A |
Kit:802.11b/g/n & BT4.0 |
N/A |
| Display |
HDMI, CVBS , LVDS/RGB |
HDMI |
mini HDMI |
mini HDMI |
MIPI/LVDS |
HDMI, MIPI |
HDMI, MIPI |
HDMI, MIPI |
HDMI, MIPI |
HDMI |
HDMI |
Kit: HDMI MIPI LVDS |
HDMI out, LVDS out |
| Camera |
Parallel 8-bit camera interface |
Parallel 8-bit camera interface MIPI Camera serial Interface(CSI) |
N/A |
N/A |
Kit: DVP camera ;MIPI camera |
1 * DVP camera interface and 1* MIP camera interface |
| Video Outputs |
HDMI 1.4@1920*1080P LVDS/Sync RGB/CPU LCD interface up to 1920x1200 Video decoding speed up to 1080p@60fps Video encoding H.264 HP up to 1080p@30fps |
HDMI 1.4 1080p@60fps Support H.265 decode by 4K@30fps, support H.264 video encoding up to 1080p@30fps |
HDMI 1.4 1080p@60fps,Support H.264 video encoding up to 1080p@30fps |
Decoding up to 1920x1080@60fps H.264 HP video encoding up to 1920x1080@60fps |
HDMI 1.4 1080p@60fps MIPI LCD interface up to 1920x1080 Decoding up to 1920x1080@60fps Video encoding H.264 HP: speed up 1920x1080@30fps |
HDMI 1.4 HEVC/H.265 decoder(SW), Main profile, 1080p@30fps H.264 video encoding up to 1080p@60fps, 720p@120fps |
HDMI 1.4 Multi-format FHD video decoding, including Mpeg1/2, Mpeg4, H.263, H.264, etc H.264 decode up to 1080P60,H.265 decode up to 4KP30 |
1080P H.264 H.265 2K/4K |
HDMI 4K/8K |
support Real-time vide decode of most popular vide formats ,such as MPEG-4,H.264,H.265. support video encoder for baseline H.264 |
| Audio Output |
3.5 mm Jack and HDMI |
HDMI |
mini HDMI |
mini HDMI |
4ohm/2.5W Speaker(2 Pin Hole) |
3.5mm Jack and HDMI |
1 * 3.5 headset jack,HDMI |
Kit: 3.5mm Jack and HDMI |
| Audino In |
Microphone |
Microphone |
NOPE |
Microphone |
Microphone |
Microphone |
Microphone |
Microphone |
Microphone |
Microphone |
Microphone |
Microphone |
kit:Microphone |
Microphone |
| GPIO |
26-PIN: GPIO, UART, I²C bus, SPI bus with two chip selects, CAN bus,PWM,+3.3 V, +5 V, ground |
40-PIN: GPIO, UART, I²C bus,I²S bus,SPI bus with two chip selects, CAN bus, PWM,+3.3 V, +5 V, ground |
40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. |
Kit: 26-PIN GPIO, UART, I²C bus, SPI bus with two chip selects, PWM,+3.3 V, +5 V, ground |
40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. CAN bus |
| Remote |
IR reciever |
IR reciever |
IR reciever |
NOPE |
NOPE |
NOPE |
IR reciever |
IR reciever |
IR reciever |
IR reciever |
NA |
IR reciever |
Kit: IR |
N/A |
| USB 2.0 Ports |
2 USB ports, 1 OTG microUSB port |
2 USB ports, 1 OTG microUSB por |
1 USB 2.0 OTG |
1 USB 2.0 OTG |
1 USB 2.0 ports, 1 OTG microUSB port |
4 USB ports, 1 OTG microUSB port |
4 USB 2.0 ports, 1 TYPE C |
Kit:1 USB ports, 1 OTG microUSB port |
2 * USB 2.0 1* USB Otg |
| Buttons |
Reset button, Power button, Uboot button |
Kit: Reset button, Power button, ADC button |
Power & Reset |
| LED |
Power LED (red), RJ45 LED (blue), user define LED (green) |
Power LED (red,Can be defined by user) |
Power led Status led |
User define LED (red/power, blue, green) |
ower Status and Activity status |
Power Status and Activity status |
Kit: User define LED (red/power, blue, green) |
3* RGB leds |
| Power |
5V/2A via MicroUSB and/or MicroUSB (OTG) |
5V/2A via DC in and/or MicroUSB (OTG) |
5V/2A via MicroUSB |
5V/2A via MicroUSB and PoE power |
5V/2Avia MicroUSB and/or MicroUSB (OTG) |
5V/2A with TYPE C or PoE |
TYPE C 5V/3A |
Kit:DC 5V/2A |
12V/2A with DC port |
| Board Size |
92mm×60mm |
92mm×60mm |
65mm×65mm |
65mm×30mm |
65mmX52.5mm |
51mm×51mm |
85mm x 55mm |
92mm×60mm |
92mm×60mm |
92mm×60mm |
92x60mm |
92mm×60mm |
67.5 x 30 mm |
