香蕉派 BPI-M5
BPI-M5介绍
Banana Pi BPI-M5是新一代单板计算机设计,采用Amlogic S905X3四核Cortex-A55 (2.0xxGHz)处理器。MP2 GPU(650Mhz)。支持4GB LPDDR4和16G eMMC板载存储。它有4个USB 3.0端口,1个千兆网口。
- Amlogic S905X3 Quad-Core Cortex-A55 (2.0xxGHz) Processor
- Mali-G31 GPU
- 4GB LPDDR4
- 16GB eMMC flash on board.
- 4 USB 3.0 port
- 1 GbE LAN por
- HDMI output
| Memory | 4 GB LPDDR4 | ||
| Network | 10/100/1000 Mbit/s Ethernet | ||
| OS | Android and Linux | ||
香蕉派BPI-M5 与 Odroid C4 和 Raspberry Pi 4硬件规格比较表
| BPI-M5 VS Odroid C4 VS RPI 4 | ||||
| Banana Pi BPI-M5 | Odroid C4 | Raspberry Pi 4 | ||
| Processor | Amlogic S905X3 Quad-Core Cortex-A55 ARMv8.2-A 64-bit 1.5GHz | Amlogic S905X3 Quad-Core Cortex-A55 ARMv8.2-A 64-bit 1.5GHz | Broadcom BCM2711, Quad core Cortex-A72 (ARM v8) 64-bit SoC @ 1.5GHz | |
| GPU | Mali-G31 MP2 GPU | Mali-G31 MP2 GPU | Broadcom VideoCore VI | |
| RAM | 4GB LPDDR4 | DDR4 memory (4GiB) | 2GB, 4GB or 8GB LPDDR4-3200 SDRAM | |
| Storage | micro SD card slot & 16GB eMMC flash on board | micro SD card slot , non EMMC | micro SD card slot, non EMMC | |
| Network | GbE ,Optional WiFi USB dongle | GbE | GbE, 2.4 GHz and 5.0 GHz IEEE 802.11ac wireless, Bluetooth 5.0, BLE | |
| Video Output | 1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID) | 1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID) | 2 × micro-HDMI 2.0 | |
| Audio Output | 3.5mm jack and 1 x HDMI digital output | N/A | 3.5 mm analogue audio-video jack | |
| DSI | N/A | N/A | 2-lane MIPI DSI display port | |
| CSI | N/A | N/A | 2-lane MIPI CSI camera port | |
| USB | USB 3.0 x 4 TYPE C | USB 3.0 x 4, 1 x Micro USB 2.0 port (OTG) | 2 USB 3.0 ports; 2 USB 2.0 ports; | |
| Power | 5 volt @3A via Micro USB (TYPE C) | 1 x DC power jack (Outer diameter : 5.5mm, inner diameter : 2.1mm) | 5V DC via USB-C connector (minimum 3A*) | |
| IR | Yes | Yes | N/A | |
| GPIO | 40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND). | 40 x GPIO pins | 40-pin GPIO header, populated | |
| Button | Reset, user and U-boot | N/A | N/A | |
| LED | Power Status and Activity status | Power Status and Activity status | Power Status and Activity status | |
| Dimensions & weight | 85x56mm, 48g | 88 mm × 58 mm × 19.5 mm, 46 g | ||
| Linux Support | Linux & Android | Linux & Android | Linux & Android | |
