Getting Started with M5/M2Pro
Revision as of 07:58, 7 October 2020 by Sinovoip (talk | contribs)
Banana Pi BPI-M5
Amlogic S905X3 Processor
Banana Pi BPI-M5 is a new generation single board computer design , use Amlogic S905X3 Quad-Core Cortex-A55 (2.0xxGHz) Processor. Mali-G31 MP2 GPU with 4 x Execution Engines (650Mhz). support 4GB LPDDR4 and 16G eMMC flash. it have 4 USB 3.0 port,1GbE LAN port.
Banana Pi BPI-M5 preliminary specifications
  • Mali-G31 MP2 GPU @ 650Mhz
  • System Memory – 4GB LPDDR4
  • Weight – 48grams
