BPI-Bit
The BPI-bit (also referred to as BPI:bit, stylised as webduino:bit) is an ESP32 with Xtensa 32bit LX6 single/dual-core processor based embedded system. support Webduino and arduino function.
BPI-bit hardware
BPI-bit hardware description
BPI:bit interface
BPI:bit edge interface
BPI-bit software
BPI:bit for webduino
BPI: bit Webduino Firmware Burning
Firmware download address:[1](https://github.com/yelvlab/BPI-BIT/tree/master/Webduino_bin)
Burning method:
One, ESP Flash Download Tool
Tool download address: [ESP Flash Download Tool](https://github.com/yelvlab/BPI-BIT/tree/master/programming/ESP_Flash_Download_Tool)
webduino srouce code
BPI:bit for arduino
