Getting Started with M64
Overview Banana Pi BPI-M64
Overview: BPI-M64 respbian linux
A64 Key Features
  • 1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor-A64
  • 2GB DDR3 SDRAM
  • 8G EMMC
  • 10/100/1000Mbps Ethernet
  • WiFi (AP6212) & Bluetooth
R18 Key Features
  • 1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor-R18
  • 2GB DDR3 SDRAM
  • 8G EMMC
Development For Android
Install Android Image on M64
Build M64 Android source code
Development For Linux
Install Linux Image
1. Prepare 8G/above TF card, USB-Serial interface, PC with Ubuntu System
2. Using your USB-Serial Connect debug console on M64
3. Install bpi-tools on your Linux PC
  $ apt-get install pv
4. Download BPI latest image
Install Image to SDcard
1. Install image with bpi-tools on Linux
plug your sd card to your Linux PC, and run
  $ sudo bpi-copy  xxx.img /dev/sdX
2. Install bpi image with Etcher on Windows, Linux and MacOS
Install Image to EMMC
1. Prepare a sd which is installed Linux image and bootup with sdcard
2. Copy emmc image to udisk then plug in M64, then mount udisk.
3. After mount udisk, use command "bpi-copy xxx-emmc-xxx.img" to install image on Emmc.
4. After success install, power off M64, eject the sdcard and poweron with emmc boot.
Switch to LCD7 bootup
  • The default release images are HDMI bootup type, you can switch to LCD bootup type after first boot.
 $ sudo bpi-bootsel /usr/lib/u-boot/bananapi/bpi-m64/BPI-M64-LCD7-linux4.4-8k.img.gz
 $ reboot
Build Linux source code
Other development and test
Use iperf3 to test gmac
1. On PC Terminal:
  • Execute "iperf3 -s"
2. On M2U console:
  • Execute "bluetoothctl"
  • Execute these commands:
WiFi on A64
  • ip link set wlan0 up
 network={
 ssid="ssid"
 psk="password"
 priority=1
  • dhclient wlan0
Ap Mode
interface=wlan0
driver=nl80211
ssid=test
hw_mode=g
channel=1
  • nmcli radio wifi off
  • rfkill unblock 1
  • rfkill unblock 2
  • ifconfig wlan0 up
  • hostapd -d hostapd.conf
  • To access a GPIO pin you first need to export it with
  • with XX being the number of the desired pin. To obtain the correct number you have to calculate it from the pin name (like PH18)
 (position of letter in alphabet - 1) * 32 + pin number
  for PH18 this would be ( 8 - 1) * 32 + 18 = 224 + 18 = 242 (since 'h' is the 8th letter)
  • echo "out/in" > /sys/class/gpio/gpio*NUMBER*/direction
  • echo "0/1" > /sys/class/gpio/gpio*NUMBER*/value
We use HDF5640 camara.
IR function
  • Execute "getevent"
  • Use your IR device to send information to A64
  • cd /usr/local/bin
WringPi
How to Update WiringPi
  • If your image is 32bit please do this command to install wring pi
  • If your image is 64bit please do:"bpi-update -c bpi-pkg-bpi-wiringpi-arm64.conf"
File System
