Getting Started with M2 Zero
[hide]Introduction
- Read more about : Banana Pi BPI-ZERO
BPI-M2 Zero
- 512MB SDRAM.
- Mini HDMI.
* Prepare 8G/above TF card, USB-Serial interface, PC with Ubuntu System * Using your USB-Serial Connect debug console on M2 Zero![]()
Install Linux Image on M2 Zero
Download latest Linux image
Install Image to SDcard on Linux PC with bpi-tools
- 1. Install bpi-tools on your system
- 2. Insert your SDcard into your PC
$ bpi-copy xxx.img /dev/sdx
- 4.After success install, power off the board, eject the sdcard and poweron with emmc boot.
Update your image
- 1. Clone M2Z repo
$ git clone https://github.com/BPI-SINOVOIP/BPI-M2Z-bsp
- 2. Build the source code according to the README.md, and update the packages to the sdcard with bpi image flashed.
How to create an image
OTG
1. On M2 Zero console:
2. On PC terminal:
USB Ethernet
- Use iperf3 to test network
- Execute "bluetoothctl"
- Execute these commands:
We use HDF5640 camara.
Display
parameters meaning:
BPI-Tools
Install Bpi-tools
Update Bpi-tools
- Execute "bpi-tools"
- cd /usr/local/bin
How to Update WiringPi
