Banana Pi BPI-M64
Revision as of 03:49, 25 April 2020 by Sinovoip (talk | contribs) (→Android)
Overview:Allwinner A64
Premium Aluminum Enclosure
BPI-M64 acrylic case
BPI-M64 for BPI 4.0 Successful case : A64 for smart home design
BPI-M64 for BPI 4.0 Successful case :A64 for IoT gateway design
Banana Pi BPI-M64 is a 64-bit quad-core mini single board computer. It features 2GB of RAM and 8GB eMMC. It also has onboard WiFi and BT. On the ports side, the BPI-M64 has 2 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, and lastly a DC power port. The processor is pin-to-pin comptialbe with R18, so it comes with two versions:M64 and M64-R18.
  • Allwinner A64 1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor.
  • 2 GB DDR3 SDRAM
  • 8G EMMC
  • 10/100/1000Mbps Ethernet
  • WiFi (AP6212) & Bluetooth
  • MIPI LCD interface
  • Camera interface
HardWare Specification of Banana pi BPI-M64
CPU Allwinner 64 Bit Quad Core ARM Cortex A53 1.2 GHz CPU
GPU Dual core Mali 400 MP2 GPU
Memory 2GB LPDDR3 (shared with GPU)
Network 10/100/1000 Mbit/s Ethernet + Wi-Fi 802.11 b/g/n + Bluetooth 4.0
Video Output(s) 1080p capable HDMI port and multi-channel audio output (NO H./X.265 capabilities)
Remote IR Receiver
LED Power Status and 8P8C
Size & Weight 92x60mm, 48g
OS Android and Linux
40 PIN GPIO of Banana pi BPI-M64
CON2-P01 VCC-3V3
CON2-P02 VCC-5V
CON2-P03 TWI1-SDA PH3
CON2-P04 VCC-5V
CON2-P05 TWI1-SCK PH2
CON2-P06 GND
CON2-P07 PH6 PH6
CON2-P08 UART2-TX PB0
CON2-P09 GND
CON2-P10 UART2-RX PB1
CON2-P11 PH7 PH7
CON2-P12 UART2-CTS PB3
CON2-P13 DMIC-CLK PH10
CON2-P14 GND
CON2-P15 DMIC-DIN PH11
CON2-P16 UART2-RTS PB2
CON2-P17 VCC-3V3
CON2-P18 PD4 PD4
CON2-P19 SPI1-MOSI PD2 UART4-TX
CON2-P20 GND
CON2-P21 SPI1-MISO PD3 UART4-RX
CON2-P22 PC0 PC0
CON2-P23 SPI1-CLK PD1 UART3-RX
CON2-P24 SPI1-CS PD0 UART3-TX
CON2-P25 GND
CON2-P26 PC2 PC2
CON2-P27 PC4 PC4
CON2-P28 PC3 PC3
CON2-P29 PC7 PC7
CON2-P30 GND
CON2-P31 PCM0-BCLK PB5
CON2-P32 PCM0-DIN PB7
CON2-P33 PCM0-SYNC PB4
CON2-P34 GND
CON2-P35 PCM0-DOUT PB6
CON2-P36 PL9 PL9
CON2-P37 PL12 PL12
CON2-P38 PL7 PL7
CON2-P39 GND
CON2-P40 PL8 PL8
CSI camer PIN define of Banana pi BPI-M64
CN5-P01 NC
CN5-P02 GND
CN5-P03 CSI0-SDA PE13
CN5-P04 CSI0-AVDD
CN5-P05 CSI0-SCK PE12
CN5-P06 CSI0-Reset PE16
CN5-P07 CSI0-VSYNC
CN5-P08 CSI0-PWDN PE17
CN5-P09 CSI0-HSYNC PE2
CN5-P10 CSI0-DVDD
CN5-P11 CSI0-DOVDD
CN5-P12 CSI0-D7 PE11
CN5-P13 CSI0-MCLK PE1
CN5-P14 CSI0-D6 PE10
CN5-P15 GND
CN5-P16 CSI0-D5 PE9
CN5-P17 CSI0-PCLK PE0
CN5-P18 CSI0-D4 PE8
CN5-P19 CSI0-D0 PE4
CN5-P20 CSI0-D3 PE7
CN5-P21 CSI0-D1 PE5
CN5-P22 CSI0-D2 PE6
CN5-P23 GND
CN5-P24 CSI0-AFVCC
MIPI DSI display PIN define of Banana pi BPI-M64
CN6-P01 VCC
CN6-P02 IPSOUT
CN6-P03 VCC
CN6-P04 IPSOUT
CN6-P05 GND
CN6-P06 IPSOUT
CN6-P07 GND
CN6-P08 IPSOUT
CN6-P09 NC
CN6-P10 GND
CN6-P11 NC
CN6-P12 DSI-D0N
CN6-P13 NC
CN6-P14 DSI-D0P
CN6-P15 NC
CN6-P16 GND
CN6-P17 TWI0-SDA PH1
CN6-P18 DSI-D1N
CN6-P19 TWI0-SCK PH0
CN6-P20 DSI-D1P
CN6-P21 CTP-INT PH4
CN6-P22 GND
CN6-P23 CTP-RST PH8
CN6-P24 DSI-CKN
CN6-P25 GND
CN6-P26 DSI-CKP
CN6-P27 LCD-BL-EN PD5
CN6-P28 GND
CN6-P29 LCD-RST PD6
CN6-P30 DSI-D2N
CN6-P31 LCD-PWR-EN PD7
CN6-P32 DSI-D2P
CN6-P33 GND
CN6-P34 GND
CN6-P35 LCD-PWM PL10
CN6-P36 DSI-D3N
CN6-P37 GND
CN6-P38 DSI-D3P
CN6-P39 NC
CN6-P40 GND
Uart PIN define of Banana pi BPI-M64
CON2 P03 UART0-TXD PB8
CON2 P02 UART0-RXD PB9
CON2 P01 GND
Win 10 IoT
banana pi BPI-M64 IOT certifying pass by Microsoft:windows 10 iot core
BPI-M64 for Win10 IoT : https://catalog.azureiotsolutions.com/details?title=Allwinner_Banana_Pi_BPI_M64&source=all-devices-page
link: https://azure.microsoft.com/en-us/documentation/articles/iot-hub-tested-configurations/
get start:
https://github.com/Azure/azure-iot-sdks/blob/master/doc/get_started/windows10-iot-core-banana-pi-bpi-m64-csharp.md
test on BPI-M64
discuss on forum: http://forum.banana-pi.org/t/banana-pi-bpi-m64-iot-certifying-pass-by-microsoft-windows-10-iot-core/2090
Windows 10 IoT Core for BPI-M64 Release Note
This document describes how to build AllWinner UEFI Firmware and bring a AllWinner dev board up with it. The AllWinner UEFI Firmware, as the major boot system for AllWinner-Windows platform, is based on the EDK2 framework which is open-source and with some AllWinner platform software packages injected.
Some updates:
1. Update the OS version to build v.10.0.15063.0 \(Creators Update\)
2. New page style of Device Portal, visit [1](https://deviceipaddr:8080) to check it
3. Built-in Cortana assistant, need to be enabled in settings page in default app and Device Portal
4. Support on-screen keyboard, need to be enabled in Device Portal
5. Enable 100M Ethernet and fix some bugs
6. Support built-in UART bus in A64 SoC\(not built in the ffu, later provide driver binary and deployment helper\)
7. Support built-in IR module in A64 SoC\(not built in the ffu, later provide source code and dev doc for developers in community\)
Known Issues:
Kernel debug is enabled by default. This will slow the bring-up process. If a kernel debug is not necessary for you, visit Device Portal and navigate to Processes->Run Command page, run this command to disable : Bcdedit /store C:\EFIESP\EFI\Microsoft\boot\BCD /set {default} debug off
An PnP bug in audio device may cause a blue screen when acting software shutdown
Ethernet device may not start with problem code 12 at the first time to bring up
And another bomb! I uploaded core driver binaries and packaging toolchains on GitHub!
Here is the repo address: https://github.com/Leeway213/BSP-aw1689
And also some driver source code here with A64 datasheet in readme: https://github.com/Leeway213/driver-samples
Welcome makers developers and anyone-elsers to post your feedback.
Microsoft Azure IoT
  • we have test BPI-M64 with Microsoft Azure IoT with aarch64 Ubuntu 18.04 Linux
Microsoft Azure IoT Edge using DPS with TPM 2.0 SLB9670 : https://www.youtube.com/watch?v=k9_GSQgKlqk&feature=youtu.be
Microsoft Azure IoT Edge using DPS with TPM 2.0 ST33 i2c : https://www.youtube.com/watch?v=2MrO1-esjwI&feature=youtu.be
  • BPI-M64 Android 7 source code
download link : https://github.com/BPI-SINOVOIP/BPI-A64-Android7
  • BPI-M64 Android 6.0.1 source code
download link : https://drive.google.com/open?id=0B_YnvHgh2rwjdTRVRVFaSHd2cnc
  • BPI-M64 (allwnner A64) Linux 4.4 source code
https://github.com/BPI-SINOVOIP/BPI-M64-bsp-4.4
Forum pthread: http://forum.banana-pi.org/t/banana-pi-bpi-m64-allwnner-a64-linux-4-4-source-code-public-on-github/6706
  • BPI-M64 Linux kernel 3.4 BSP code:
github link : https://github.com/BPI-SINOVOIP/BPI-M64-bsp
  • BPI-M64 Win10 IoT source code
https://bananapi.gitbooks.io/bpi-m64/content/en/sourcecodeongithub.html
  • BPI-M64 Robot Operating System (ROS):
github: https://github.com/techping/BPI-robot-1
discuss on forum: http://forum.banana-pi.org/t/discuss-robot-operating-system-ros-on-banana-pi/10967
documents
  • schematic diagram:
google driver : https://drive.google.com/file/d/0B4PAo2nW2KfnUE5tMGItNkZjMzg/view?usp=sharing
baidu cloud : http://pan.baidu.com/s/1kVRpcYb
BPI-M64 BT Lab test :https://bananapi.gitbooks.io/bpi-m64/content/en/bpi-m64bt40labtest.html
BPI-M64 WIFI Lab test :https://bananapi.gitbooks.io/bpi-m64/content/en/bpi-m264wifilabtest.html
BPI-M64 Validation test : https://bananapi.gitbooks.io/bpi-m64/content/en/bpi-m64validationtestreport.html
CE FCC RoHS : http://forum.banana-pi.org/t/bpi-m64-ce-fcc-rohs-certification/2747
Amazon AWS Greengrass
Banana Pi BPI-M64 passed Amazon AWS Greengrass:https://devices.amazonaws.com/detail/a3G0h000000OvPoEAK/Banana-Pi-BPI-M64
  • BPI-M64 new image: Rasbian ,Ubuntu Debian 2020-04-21 updae
2020-04-21-ubuntu-18.04-mate-desktop-bpi-m64-aarch64-sd-emmc.img.zip
2020-04-21-ubuntu-16.04-server-bpi-m64-aarch64-sd-emmc.img.zip
2020-04-21-raspbian-stretch-bpi-m64-sd-emmc.img.zip
google drive:https://drive.google.com/drive/folders/0B_YnvHgh2rwja3I4SllZN2VkYm8
baidu cloud:https://pan.baidu.com/s/18XH8_uusUGBusbp4xw4txQ Pincode:36R0
  • 2018-10-24 update Android 6.0 & 7.0 & 8.1 Release,his release is for banana pi M64 board which is based on Allwinner A64, We release three Images, Android is based on kernel 3.10.
  • M64 Android 6.0 HDMI & LCD7
Features Map: http://wiki.banana-pi.org/M64_Image_Map#Android_6.0
HDMI Version Image Links:
Google Drive : https://drive.google.com/open?id=1Em7ZXVvbJI7wMXy_TM4VNwHo6Oa-vVBc
Baidu Drive : https://pan.baidu.com/s/1ZginIvO3LVakqokIZAX1Xw
LCD7 Version Image Links:
Google Drive : https://drive.google.com/open?id=1Tts1krZyzwz9mL90j1ilTzVrJm6hh_J4
Baidu Drive : https://pan.baidu.com/s/1oKMx_Ml5K1Jv7-qeS-NMsQ
  • M64 Android 7.0 HDMI & LCD7
Features Map:http://wiki.banana-pi.org/M64_Image_Map#Android_7.0
Google Drive : https://drive.google.com/open?id=1mvKyK6KuPixs-jLD0FocIaV465bJ1Eig
Baidu Drive : https://pan.baidu.com/s/15b32TXdh6752c-GBnR-Zeg
Google Drive : https://drive.google.com/open?id=16Ffc5xiZgD7JYgrMtCGaOYLCuZdQGcnY
Baidu Drive : https://pan.baidu.com/s/1a9RYKSTRhCO-UzFfIoGCtQ
  • BPI-M64 Android 8.1 HDMI & LCD7
Features Map:http://wiki.banana-pi.org/M64_Image_Map#Android_8.1
Google Drive : https://drive.google.com/open?id=1UBaH9CNbmC9-n3jGImrFIAPZ8aZhqMJz
Baidu Drive : https://pan.baidu.com/s/1lz57HrqNHx6f_Q6nk0oZvA
Google Drive : https://drive.google.com/open?id=1wktuCcvolfozMFkLmugfZtGziHDj-1EM
Baidu Drive : https://pan.baidu.com/s/1MteYqyBp8LeECjcDteCTZQ
  • 2018-9-17 update android 6.0
Features Map :http://wiki.banana-pi.org/M64_Image_Map#Android_6.0
Google Drive : https://drive.google.com/open?id=19ExJ9Ztfy3UgK9NZ4SiaVZAMozgyCJl7
Baidu Drive : https://pan.baidu.com/s/1s_orgiEI7JU_hUgjnpd25w
Google Drive : https://drive.google.com/open?id=1gWD_IT0P4NvdeqtK5I4MnJjwzsP7SXJc
Baidu Drive : https://pan.baidu.com/s/1K0HYPiQe6nGvAS5bAAFHow
Forum pthread : http://forum.banana-pi.org/t/banana-pi-bpi-m64-new-images-release-2018-09-18/6796
  • 2018-08-17 update,android 8.1
This release is for banana pi M64 board which is based on Allwinner A64, We have two images release,Android 8.1 is based on kernel 4.9
BPI-M64 Android 8.1 Features Map:http://wiki.banana-pi.org/M64_Image_Map#Android_8.1
HDMI-LCD-Version:
Google Drive : https://drive.google.com/open?id=11XjvTAbPw57R6H5kL27GVXry4xu18dVs
Baidu Drive : https://pan.baidu.com/s/1PQgJCUo6cY3wWxJ7rZrk-A
Forum pthread:http://forum.banana-pi.org/t/bananapi-bpi-m64-a64-new-image-android-8-1-ubuntu-release-2018-08-17/6531
  • 2018-05-20 update ,android 7.0
hdmi-Version and Lcd 5.0 version
baidu cloud : https://pan.baidu.com/s/1O3PsI73WmFFvhxMmzEscIQ
  • 2017-05-11 update ,android 6.0
HDMI-Version
Google Drive:https://drive.google.com/open?id=0B_YnvHgh2rwjcF9USm1MWWtxSXc
Baidu Cloud:https://pan.baidu.com/s/1bHWhlW
MD5: f85281213b9c5b88008a487dd1b6963c
LCD-Version
Google Drive:https://drive.google.com/open?id=0B_YnvHgh2rwjdHpFbHJMQWtsbFk
Baidu Cloud:https://pan.baidu.com/s/1kVJVPGV
MD5:be27e4eced96d3de81d46e512fd978eb
forum pthread:http://forum.banana-pi.org/t/bpi-m64-new-image-android-6-0-version-v3/3240/4
Win 10 IoT
  • 2017-1-13 updae Win10 IoT Core beta0.2
baidu cloud :http://pan.baidu.com/s/1c2ce100
  • Win10 IoT Core 10586 beta0.1
download link : https://drive.google.com/open?id=0B_YnvHgh2rwjODJOSS1TdkRvcEk
baidu link : http://pan.baidu.com/s/1dEQyGgD
MD5: 1c09118cd45bf0c3b61d1846710a3649
  • 2018-11-2 update This release is for banana pi M64 board which is based on Allwinner A64, We release three Images, Ubuntu 16.04 Desktop & AARCH64 is based on kernel 3.10 & kernel 4.4.
BPI-M64 Ubuntu 16.04 Desktp
Features Map: http://wiki.banana-pi.org/M64_Image_Map#Ubuntu_Desktop_16.04
Google Drive : https://drive.google.com/file/d/1YzdkY8i-IsXzXLkbPCPNbAuhYbHmUwgv/view
Baidu Drive : https://pan.baidu.com/s/1XhOJBQtPkhvidjgipFNdzg
md5sum : 3564f0d3de9936aa26b93eaf027703a0
BPI-M64 Ubuntu 16.04 AARCH64 Kernel 3.10
Features Map : http://wiki.banana-pi.org/M64_Image_Map#Ubuntu_Desktop_aarch64_16.04
Google Drive : Chttps://drive.google.com/file/d/1MglySZLvquRPu1Wj8oLwdKBkFnRzLUL-/view
Baidu Drive : https://pan.baidu.com/s/1_ZTDCuL9QZf6qrqaE4gbgQ
md5sum : 7422e02daa01bff6de808490e89b436e
BPI-M64 Ubuntu 16.04 AARCH64 Kernel 4.4
features Map:http://wiki.banana-pi.org/M64_Image_Map#Kernel_4.4.89
Google Drive : https://drive.google.com/file/d/1g_m1NLn1-wUQ8jjPKEAwQcSj4d4P9vRP/view
Baidu Drive : https://pan.baidu.com/s/1JmKQGRKvJ9DwL_ij0K79FA
md5sum : ea9bba6ab7fc78f7b8478bfd013a9b50
forum pthread: http://forum.banana-pi.org/t/banana-pi-bpi-m64-new-images-ubuntu16-04-desktop-aarch64-release-2018-11-1/7159/1
kernel 4.4
  • About this release:This release is for banana pi M64 board which is based on Allwinner A64, We release two Images, Debian 9.5 AARCH64 is based kernel 4.4.
2.M64 Debian 9.5 AARCH64 Kernel 3.10
Features Map http://wiki.banana-pi.org/M64_Image_Map#Debian_9.5_AARCH64 Image Links: Google Drive : Coming soon
Baidu Drive : https://pan.baidu.com/s/1DJd7CGAT0NiijKfOBq9J4Q
md5sum : 71fe25c1922c7f9ef81bb88e0f544de6
  • 2018-4-17 update Ubuntu 16.04.4 with linux kernel 4.4.89
image name:2018-04-17-ubuntu-16.04-mate-desktop-demo3-k4.4.89-vdpau-3-mic-docker-bpi-r18-avs-aarch64-sd-emmc.img.zip
Google Drive: https://drive.google.com/open?id=1dlfo9LGNcrc-_cpKd1uJnrNx0PdonBnK
MD5: 4b7e163d260e58a39ba8905e7ed39943
Forum pthread:http://forum.banana-pi.org/t/bpi-r18-avs-new-image-ubuntu-16-04-4-with-linux-kernel-4-4-89-2018-4-17/5435
Kernel 3.10.105
  • 2018-09-18 This release is for banana pi M64 board which is based on Allwinner A64, We release three Images, Ubuntu 16.04 Desktop & Android is based on kernel 3.10.
Features Map :http://wiki.banana-pi.org/M64_Image_Map#Ubuntu_Desktop_16.04
Google Drive :
Baidu Drive : https://pan.baidu.com/s/1wANJ4SwfNwKtBcd02WcbWA
forum pthread : http://forum.banana-pi.org/t/banana-pi-bpi-m64-new-images-release-2018-09-18/6796
  • 2018-08-17 update Ubuntu 16.04 Server kernel 3.10.105
Google Drive : https://drive.google.com/open?id=1K-B4u8jGcv17s3I9v-Pr0xv5u5txvfok
Baidu Drive : https://pan.baidu.com/s/1HcrR8NsL9_1RwbZNa7uwmg
  • 2017-08-14 update based on ubuntu 16.04.3 LTS Mate Desktop (64-bit),support BPI-M64 kernel 3.10.105
Google Drive: https://drive.google.com/file/d/0B_YnvHgh2rwjN1h1U0xDYUxET00/view?usp=sharing
baidu cloud: http://pan.baidu.com/s/1pLkbdTT
MD5: ae34baa840874276858d936a7ca85c4f
Forum pthread:http://forum.banana-pi.org/t/bpi-m64-new-image-2017-08-14-ubuntu-16-04-mate-desktop-beta-aarch64-bpi-m64-sd-emmc/3695
  • 2018-11-2 update , This release is for banana pi M64 board which is based on Allwinner A64, We release two Images, Debian 9.5 AARCH64 is based on kernel 3.10 & kernel 4.4.
Features Map : * http://wiki.banana-pi.org/M64_Image_Map#Debian_9.5_AARCH64
Google driver : https://drive.google.com/file/d/10qGv2gVrSgwXMBLDsCF0nQFc9EJnnkeS/view
M64 Debian 9.5 AARCH64 Kernel 4.4
Features Map: * http://wiki.banana-pi.org/M64_Image_Map#Debian_9.5_AARCH64
Google Drive : https://drive.google.com/file/d/17fh3YY6cwOzHMsqwnRQRTu9cXjKU4_tV/view
Baidu Drive : https://pan.baidu.com/s/1sOR6WFz2U9MT0ltq6zYnJA
md5sum : f3c2391b0232178018fda7ebfd64b14c
forum pthread:http://forum.banana-pi.org/t/banana-pi-bpi-m64-new-images-debian-9-5-aarch64-release-2018-11-02/7166
  • 2017-08-13 debian 8.9 jessie Mate Desktop (64-bit),support BPI-M64 kernel 3.10.105
Google Drive:https://drive.google.com/file/d/0B_YnvHgh2rwjazlNRTRHei1NbmM/view?usp=sharing
baidu cloud:http://pan.baidu.com/s/1eSeTQeA
MD5: 9ddf067457ebaf193de63c5c7141446a
Forum pthread:http://forum.banana-pi.org/t/bpi-m64-new-image-2017-08-13-debian-8-jessie-mate-desktop-preview-aarch64-bpi-m64-sd-emmc/3694
  • Armbian Updated images for Bananapi M64 with LTS kernel 4.19.y:
https://www.armbian.com/bananapi-m64/?fbclid=IwAR3w3BGU7C9uAZim-Po2vSdyE0ylEdzr4QnqJ3ruYkuSxrtetGhst3-jomo
known issue:WiFi doesn't work
Image lownload link :https://www.armbian.com/bananapi-m64/
  • Armbian OS aarch64
download link:http://geektillithertz.com/wordpress/index.php/2017/01/04/armbian-os-banana-pi-m64/
Forum pthread:http://forum.banana-pi.org/t/bpi-m64-new-image-armbian-os-aarch64-for-bpi-m64-download/2724
Raspbian
  • 2018-11-06 update : This release is for banana pi M64 board which is based on Allwinner A64, We release two Images, Raspbian 9.4 is based on kernel 3.10 & kernel 4.4.
BPI-M64 Raspbian 9.4 Kernel 3.10
Features Map : http://wiki.banana-pi.org/M64_Image_Map#Raspbian_9.4_AARCH64
Google Drive : https://drive.google.com/file/d/1qoKCVDgiuEj0IVEzuPgzuFLjFR9hTLH8/view
Baidu Drive : https://pan.baidu.com/s/1MlIzQRpjs_soBDXOKf8NAw
md5sum : e321c6dbb096a0348fceb9d4a0b6c210
BPI-M64 Raspbian 9.4 Kernel 4.4
Features Map : http://wiki.banana-pi.org/M64_Image_Map#Kernel_4.4.89_4
Google Drive : https://drive.google.com/file/d/1WnsHKnbI_FWQVkHQmbCcJ3yJ38oWaHGy/view
Baidu Drive : https://pan.baidu.com/s/1Bu-xiqiYsnau_xZp8-QEkw
md5sum : 1d4f00680e6869e2c4e66e205e61d93d
forum pthread: http://forum.banana-pi.org/t/banana-pi-bpi-m64-new-images-raspbian-9-4-kernel-3-10-4-4-release-2018-11-06/7195
Fedora Linux
  • BPI-M64 fedora image download(not support desktop): fedora 31 with grub (u-boot-2019.07 + kernel 5.3.0)
https://drive.google.com/file/d/1dIr943Ke28lEtCDpy8cI3q1dBUtHymJP/view?usp=drivesdk
https://drive.google.com/file/d/1F3nYOw9AiLLaz8be0umz_9nlnhDP3t0s/view?usp=drivesdk
Forum pthread:http://forum.banana-pi.org/t/bananapi-bpi-m64-new-image-fedora-31-with-grub-u-boot-2019-07-kernel-5-3-0/9938
Manjaro
  • 2019-01-15 update,BananaPi BPI-M64 Support Run Manjaro AArch64 System
Baidu Drive: https://pan.baidu.com/s/18drwPBFKAzf4lFe6IPjaPA
Google Drive: https://drive.google.com/open?id=1Lu8xw4sAVyiHJT4eYcolNTAIKG154gm6
Bpi Ftp Server: https://dev.banana-pi.org.cn/Image/BPI-M64/Manjaro/
md5sum : 8c9964fbd80836228c72fa205eb62f78
username: manjaro/root
password: bananapi
Forum pthread:http://forum.banana-pi.org/t/bananapi-bpi-m64-new-image-manjaro-aarch64-system-2019-01-16/7696
FreeBSD
Clonezilla
Others
  • 1,How-to use ubuntu system to support lcd7**?
1."vi /media/pi/BPI-BOOT/bananapi/bpi-m64/linux/lcd7/uEnv.txt"
2.If you use HC070TG lcd7 screen, change "touch=gt9xxnew_ts" But if you use S070WV20 lcd7 screen, you don't need to change.
3. "bpi-bootsel /usr/lib/u-boot/bananapi/bpi-m64/u-boot-with-dtb-bpi-m64-lcd7-8k.img.gz"
4.reboot
For more operation details please see Wiki: http://wiki.banana-pi.org/Getting_Started_with_M64
