Banana Pi BPI-F2P
Revision as of 02:22, 20 April 2020 by Sinovoip (talk | contribs)
BPI-F2S with Heat sinks ,PoE module and RTC battery on board
sunplus SF7021 chip design
Xilinx Artix-7 XC7A100T FPGA board
Industrial operating
SunPlus SP7021 Diagram
SunPlus SP7021
Banana Pi BPI-F2P use Sunplus chip design, this is a industrial control board. use Plus1(sp7021) design. it support PoE function with PoE module,and support RS232 and RS485 . so you can use it do a Industrial control gateway.
Application direction
  • Smart Audio
  • Smart Payment system
about SunPlus SP7021
characteristics of the SP7021
  • Easy-to-use LQFP package.
  • Single 3.3V power*.
  • 10-year supply guarantee.
  • And much more...
  • SoC – Sunplus SP7021 “Plus1” with a quad-core Cortex-A7 processor @ 1.0 GHz, one Arm A926 microprocessor, an 8051 core to handle I/Os, and 128MB or 512MB DDR3 DRAM.
  • Storage – 8GB eMMC flash, microSD card slot
  • Video Output – HDMI 1.4 output
  • Camera I/F – MIPI CSI connector
  • Connectivity – 2x 10/100M Ethernet
  • USB – 2x USB 2.0 host ports, 1x micro USB port
  • Expansion
2 USB header interface
40-pin GPIO header compatible
7.4V Lithium battery power supply interface
RTC battery interface
PoE function support
  • Debugging – 3-pin header for UART console, SWD ICE port
  • Security – TPM 2.0 via ST33TPH2EI2C secure element
  • Power Supply – 12VDC via power barrel jack
  • Dimensions – Still not documented
  • Temperature Range – -40C ~ +85°C
Source code on github
Ubuntu Linux
  • 2019-12-25 update :ubuntu mate 18.04 desktop 2019-12-25 base on kernel 4.19.37
file name : 2019-12-25-ubuntu-mate-18.04.2-beta1-desktop-armhf+raspi-ext4-bpi-f2s.img.zip
google link:https://drive.google.com/file/d/1_TJzJPMm89Fb9Fji1PddMPas-EEO-IGw/view
discuss on forum:http://forum.banana-pi.org/t/bpi-f2s-new-image-ubuntu-mate-18-04-desktop-2019-12-25/10454
Kail Linux
file name:2019-12-25-kali-linux-2019.4-rpi3-nexmon-bpi-f2s.img.zip
google link:https://drive.google.com/file/d/19G49t288CKKLGokI-jQOs9h7rtsxGBGo/view?usp=drivesdk
password: root/toor
discuss on forum:http://forum.banana-pi.org/t/bpi-f2s-new-image-kail-linux-2019-4-nexmon-2019-12-25/10453
Debian Linux
file name: 2019-11-29-debian-10-buster-mate-desktop-beta-bpi-f2s-sd-emmc.img.zip
google download link: https://drive.google.com/file/d/1MpjDeUk4H-EXzaxpuywgbgRaM8YXoXjI/view
Discuss on forum: http://forum.banana-pi.org/t/bpi-f2s-new-image-debian-10-buste-bpi-f2s-sd-emmc-2019-11-26/10270
CentOS linux
file name:2019-12-25-CentOS-Userland-7-armv7hl-RaspberryPI-KDE-1908-sda.raw.xz-bpi-f2s.img.zip
google link:https://drive.google.com/file/d/1Is-BS7lvCUrRBkO7wCjn4q51eI7Yof-l/view
password:root/centos
discuss on forum:http://forum.banana-pi.org/t/bpi-f2s-new-image-centos-userland-armv7hl-raspberrypi-kde-1908-sda-2019-12-25/10452
Fedora-Mate
Mozilla IoT gateway
file name:2019-12-25-rpi-gateway-0.10.0-bpi-f2s.img.zip
google link:https://drive.google.com/file/d/1wPDeqQpKce-I81fQ638HE_ogl-MDkOOB/view?usp=drivesdk
Mozilla gateway getting started guide:https://iot.mozilla.org/docs/gateway-getting-started-guide.html
discuss on forum :http://forum.banana-pi.org/t/bpi-f2s-new-image-mozilla-iot-rpi-gateway-0-10-0-2019-12-25/10455
Yocto Linux
github link: https://github.com/tibbotech/yocto_layers
