Sweet fume machine Intelligent sleep meter design
Revision as of 23:41, 4 February 2020 by Sinovoip (talk | contribs) (ENERGY Essential Oil)
Sweet fume machine
KRKI G3 smart sleep regulator, which combines three-dimensional signals of temporal biorhythm (functional odor small molecules, smart light,Full frequency background), can really arouse brain internal sleep to get up ਀ program.Through scientific sleep algorithms, release The corresponding sleep signal can reshape the user's sleep rhythm and safely improve the user's sleep quality.Achieve comfortable and natural during the day Wake up, sleep soundly at night.
Explanation: intelligent sleep regulator integrates sleep monitoring and sleep rhythm adjustment, and combines time biorhythm Three-dimensional signals (functional odor small molecules, intelligent light, full-band background sounds) can provide a full cycle of sleep from sleep to wake up Sleep solution, safe and no side effects to improve the quality of sleep users.Through collecting the user's sleep data, analyze the user .The biological clock status of the intelligent generation of user personalized sleep algorithm.The algorithm can be based on the user's environment and sleep status,Release corresponding concentration (intensity) of sleep assistance signal, reshape the user's sleep rhythm, improve the user's sleep quality.
this patented formula of plant extracts are food grade, safe and non-toxic side effects.
In the Sleep aid phase, ERKI G3 releases the patented formula for "Sleep" plant essence.Odor signals pass through the body's sense of smell Organs that bypass the hypothalamus to communicate directly to the cerebral cortex and reduce its activity, lowering serum cortisol levels and relieving the pain User nervous anxiety.At the same time intelligent sleep light effect on the hypothalamus ৿ depending on the intersection of nucleus (SCN), promote the body The secretion of melatonin makes the user feel sleepy. With Della to help sleep, it helps the user to sleep more efficiently State.
In the wake phase, according to the user set wake-up time in advance to user signs, quantitative release has the patent "Energy" is the essence of plants.Scent signals bypass the inactive hypothalamus when a person is asleep Direct to the cerebral cortex, gradually the user's sleep state from deep sleep to light sleep, while improving the activity of the hypothalamus Jerk.Then, intelligent wake up light effect on the visual / ৿ nuclear SCN, promote the decomposition of melatonin.Finally, match Della's evocation Music, let the user inadvertently wake up, so that the completion of a "enjoy good sleep".
Main fcunction
  • ESP32-WROVER chip design
  • Support WiFi, MQTT protocol connect to Server
  • Support BT ,can use BT setting
  • Support online music play
  • App support
PCBA design
with case
Essential Oil
Shanghai Jiao tong University Aromatic Plant R & D Center Technical Support
Similarly, there is no essential oil developed by real scientists in a scientific way. In the laboratory, we found that lavender essential oils have low sleep efficiency for Asians. Therefore, the effectiveness of essential oils on the market is not clear, and the target population is dislocated.
ERKI cooperated with Shanghai Jiao tong University's Aromatic Plant R & D Center, the earliest and largest aromatic product research and development base in China, and conducted thousands of mouse tests and human saliva and sleep brain wave experiments through a doctoral supervisor and doctoral team to develop Secret formula essential oils which is suitable for Asia human sleep. In human body experiments, set up a control group , after eliminating psychological factors, the overall effect of improving sleep efficiency, shortening the time to fall asleep, and extending the total sleep time is more than 60%. The effect of general sleep aid drugs is 20-30%, but this essential oil is made of natural materials and organic plants, which can be naturally accepted by the human body, triggering sleep reflection in the brain, and can metabolize small molecules of odor in a short time.
  • Bottle type: round
  • Capacity: 10ml
  • Properties: This product is an oily plant essential oil extract (no other solvents)
  • Main ingredients: Rutaceae plant, linalool, lilac bud and other plant extracts, 100% pure natural plant extract
  • Usage and Dosage: Quantitative use according to the built-in algorithm, ideal dosage is 0.3ml / h
  • Principle of action: After sniffing, it activates the cerebral cortex through the nerve's ascending pathway on the second day of the brain, and acts on the nerve's ascending pathway on the first day to assist the hypothalamic wake mechanism
  • Effect: After experiment, in the absence of other stimulating conditions, the essential oil can wake the subject painlessly after sniffing for about 12 minutes, and there is no headache or dizziness.
Note:
  • Use with caution: pregnant women, people with tracheal diseases should consult ERKI
  • Adverse reactions: large concentration and large dose may cause burns to the respiratory tract
  • Store at room temperature away from light. If you feel unwell, stop using it immediately and consult ERKI for professional advice.
SLEEP Compound Essential Oil
  • Capacity: 10ml
  • Main ingredients: linalool, rose, sandalwood and other plant extracts 100% natural plant extracts
  • Usage Dosage: Quantitative use according to the built-in algorithm, ideal dosage is 0.3ml / h
  • Principle of action: Change the amines in the brain through sniffing, convert brain waves from β waves to δ and θ waves, promote the stability of the cerebral cortex and induce sleep reflexes
  • Effect: After clinical experiments, the sleep-promoting effect (reducing sleep time and delaying sleep state) can reach 60%, which is much higher than the general sleep medicine products (20-30%), and the plant essential oil molecules can be metabolized or expelled from human body within a few days . Non-addictive
note:
  • Use with caution: pregnant women and those with tracheal diseases should consult ERKI.
  • Prohibited: High altitude operator, operators of precision instruments, and drivers at working are prohibited from using it
OEM & ODM
if anyone like to OME & ODM this product ,please send mail to [email protected]
