Banana Pi BPI-F2S
Revision as of 02:12, 23 December 2019 by Sinovoip (talk | contribs)
Banana Pi BPI-F2S
File:Banana PI BPI-F2S 4.JPG
sunplus SF7021 chip design
File:Banana PI BPI-F2S 5.JPG
Industrial operating
SunPlus SP7021 Diagram
Banana Pi BPI-F2S is the first board with Banana Pi team and SunPlus, this is a industrial-grade board. use Plus1(sp7021) design.
Application direction
  • Smart Audio
  • Smart Payment system
  • FPGA education and development
about SunPlus SP7021
characteristics of the SP7021
  • Easy-to-use LQFP package.
  • Single 3.3V power*.
  • 10-year supply guarantee.
  • And much more...
note : 40 PIN GPIO compitable Raspberry Pi
File:Banana Pi FPGA kit.JPG
Kit include
  • 1. BPI-F2S sunplus board
  • 2. FPGA baord: Xilinx Artix-7 XC7A100T,32 MByte QSPI Flash memory,power by single 3.3v
  • 3. teaching sheet board : 4 digit 7 segment digital tube teaching,DIP8 socket for SPI flash IP authentication,8 LED lights are used for teaching
  • 4. debug tooling
  • 5. 12v/2A adapter
online documents:
Key Features:
  • Xilinx Artix-7 XC7A100T-2CSG324C
  • 32 MByte Flash memory
  • 95 I/O's (42 + 42 + 3 + 8)
  • I2C EEPROM
  • 7.3 x 3.5 cm form factor
  • JTAG/UART connector
  • One user LED
Source code on github
Fedora-Mate
