Banana Pi BPI-R64
MTK MT7622
- 1G DDR3 SDRAM
- MTK7615 4x4ac wifi (option)
- support 1 SATA interface
- (1) USB 3.0
- POE function support
Read more for development :Getting Started with R64
Frank wiki : http://fw-web.de/dokuwiki/doku.php?id=en:bpi-r64:start
Hardware Revision
| HardWare Specification of Banana pi BPI-R64 | |||
| SDRAM | 1 GB DDR3 | ||
| SATA | support 1 SATA interface | ||
| On board Network | 5 10/100/1000Mbps Ethernet | ||
| Wifi | built-in 4x4n 802.11n (800Mbps) sysem-on-chip and MTK7615 4x4ac wifi Module (1733Mbps) (option) | ||
| USB | 1 USB 3.0 host | ||
| Buttons | Reset button | ||
| IR | PIN define with GPIO | ||
| DC Power | 12V/2A with DC in | ||
| Weight | 100g | ||
PoE support
more PoE module spec
4G support
BPI-R64 GPIO Pin define
- frank github(kernel 5.4): https://github.com/frank-w/BPI-R2-4.14/tree/5.4-r64-dsa
- OpenWRT: https://github.com/openwrt/openwrt/tree/master/target/linux/mediatek/mt7622
- BPI-R64 schematic diagram
- google https://drive.google.com/file/d/1QzKmIwgSNbCIXQbqLsTUELJCEPik3VGr/view?usp=sharing
- baidu cloud link: https://pan.baidu.com/s/18MEJpr5OTYmySZoyk3bO5Q pincode: amqt
- BPI-R64 DXF file for case deign : https://drive.google.com/file/d/1_YNsdQ9Cv7FVOGrqd6GP0Tu5u2cjLwTA/view?usp=sharing
- MTK MT7622A_Datasheet_for_BananaPi_Only : https://drive.google.com/file/d/1DVEv3bovA8cPti3Ln7d9lDBjMCGFSE5m/view?usp=sharing
- MT7622 Reference Manual for Develope Board(BPi) : https://drive.google.com/file/d/1cW8KQmmVpwDGmBd48KNQes9CRn7FEgBb/view?usp=sharing
- Banana Pi BPI-R64 debian Linux boot demo and bootlog:http://forum.banana-pi.org/t/banana-pi-bpi-r64-debian-linux-boot-demo-and-bootlog/8155
- Banana Pi BPI-R64 passed AWS Greengrass : https://devices.amazonaws.com/detail/a3G0h000000OvObEAK/Banana-Pi-R64
- Bpi-r64 quick start (boot from eMMC):http://forum.banana-pi.org/t/bpi-r64-quick-start-boot-from-emmc/9809
- Banana Pi BPI-R64 CE,FCC,RoHS Certification : http://forum.banana-pi.org/t/banana-pi-bpi-r64-open-source-router-board-ce-fcc-rohs-certification/10094
Amazon AWS Greengrass
Release
- Fetures Map:
- Google Drive : https://drive.google.com/open?id=1zrOSS2QJPirSwoK5yJFx10SiOtxRjXPt
- Fetures Map:
AArch64 Linux
- Fetures Map:
- easy to buy sample: BPI official Aliexpress shop
