Banana Pi BPI-F2S
Banana Pi BPI-F2S is the first board with Banana Pi team and SunPlus, this is a industrial-grade board. use Plus1(sp7021) design.
about SunPlus sf7021
SunPlus sf7021 is a revolutionary SoC that has the power of a Linux-grade chip and the integration simplicity of a microcontroller.it with ARM Cortex-A7 Quad core,ARM926 real-time core,8051 low-power core
characteristics of the SP7021
- Easy-to-use LQFP package.
- Single 3.3V power*.
- 10-year supply guarantee.
- And much more...
FPGA extend board
Source code on github
