香蕉派 BPI-R64
Revision as of 08:14, 28 October 2019 by Sinovoip (talk | contribs) (文档)
产品介绍
File:Banana Pi BPI-R64 6.jpg
Banana Pi BPI-R64 with MT7622
Overview:banana Pi BPI-R64
File:BPI-R64 POE 1.jpg
BPI:4.0 Successful case 5G/4G 多卡聚合融合通信网关
4G with USB 4G module via USB
MTK MT7622 芯片
  • 1G DDR3 SDRAM
  • MTK7615 4x4ac wifi on board
  • support 1 SATA interface
  • (1) USB 3.0
  • POE function support
开始使用
如何使用BPI-R64进行开发 :Getting Started with R64
硬件接口示意
Banana pi BPI-R64 硬件规格
SDRAM 1 GB DDR3
SATA support 1 SATA interface
On board Network 5 10/100/1000Mbps Ethernet with MT7531 switch chip
USB 1 USB 3.0 host
Buttons Reset button
IR onboard IR receiver
DC Power 5V/2A with DC in
Sizes 148 mm × 100.5mm
Weight 100g
PoE 网线供电支持
more PoE module spec
4G 支持
2,也可以采用USB接口的扩展模块
我们开发了 MT7615 802.11 ac wifi 模组,可以方便的使用在 BPI-R64
BPI-R64 GPIO Pin define
资源
软件源代码
文档
google drive link: https://drive.google.com/file/d/1cW8KQmmVpwDGmBd48KNQes9CRn7FEgBb/view?usp=sharing
BaiDu Drive:https://pan.baidu.com/s/1KduFT2MUvMs2FhOF4A8kQQ
Amazon AWS 认证
镜像发布
Fetures Map:
Google Drive : https://drive.google.com/open?id=1zrOSS2QJPirSwoK5yJFx10SiOtxRjXP
Fetures Map:
AArch64 Linux
Fetures Map:
