BPI:bit MoonCar 登月小车
Revision as of 22:52, 25 September 2019 by Sinovoip (talk | contribs) (power source)
小车介绍
BPI:bit MoonCar
BPI:bit MoonCar
BPI:bit MoonCar
MoonCar with BPI:bit
MoonCar with Micro:bit
BPI:Bit MoonCar登月小车由Webduino 和 iCShop 合作开发,由banana Pi生产,是专门为 BPI:Bit 和 Micro:bit开发板所设计的自走车,内建巡迹功能、颜色感测、红外线发射接收与按钮,结合 Web:Bit 就能让点矩阵显示各种颜色的图案。前方保留超音波的脚位,可实作自动避障功能。透过webduino Web:Bit 教育版就能轻松实现更多有趣的控制方式!也可以配合Micro:bit 和makecode环境编程
动力来源
MoonCar 配置两个微型金属马达以及一颗辅助轮,相较于搭配塑胶齿轮箱的马达有较好的品质与耐用性。辅助轮特别选用非金属材质,行进时可减少因与地面敲击产生之杂音。
IR (Sending and receiving messages)
The front of the MoonCar is equipped with a pair of infrared emission and reception, through the general infrared remote control to its instructions. Infrared transmitters can send messages to communicate with other mooncars, making it much more playable.
buzzer (make a sound)
On the right side of the MoonCar is a passive buzzer that can be programmed to produce different sounds, such as an electronic organ or an alarm or a ringtone. I can edit the statements generated by different notes and pauses to make MoonCar sound like talking.
Magic lantern
Linear sensor (Track the line running)
Color identification
Expansion function
Considerate design
Conclusion
Use with BPI:bit
Use with Micro:bit
Sourcode on github
Mooncar project : https://github.com/iCShopMgr/MoonCar
