Getting Started with M4
Revision as of 12:03, 16 August 2019 by Dangku (talk | contribs) (Docs)
BPI-M4
Overview Banana Pi BPI-M4
Overview:Realtek RTD1395
  • 8G eMMC flash (max 64 GB)
  • USB 2.0 TYPE C
  • PoE function support
Development For Android
Install Android
1.Install bootcode (in bpi-m4_bootcode&bootloader_20190625.zip)
1.1 Connect BPI-M4 and PC with debug console, Switch BPI-M4 SW2 to 1, open "hypertrm.exe" on PC.
1.2 Set Baud rate: 115200, data bit: 8 bit, stop bit: 1 bit, Parity: NONE, Flow control: NONE
1.3 Press "Ctrl+q" on PC, then power on BPI-M4, hypertrm will print "/d/g/r"
1.4 Press “h” button on PC,choose Transfer->Send File in the menu, then choose file ” bootcode/android_2133/hwsetting.bin”(or RTD1395_hwsetting_BOOT_2DDR4_ 8Gb_s2133.bin) , protocol choose “Ymodem-G”.
1.5 After send file, if transfer successfully, you will see the following picture:
1.6 Press “d” button on PC,choose Transfer->Send File in the menu, then choose file ” bootcode/android_2133/recovery.bin(or Recovery-bananapi-0001-RTD1395 _hwsetting_BOOT_2DDR4_8Gb_s2133.bin) , choose “Ymodem-G”.
1.7 After transfer these two files, press “g” to execute it.
2.Install bootloader (in bpi-m4_bootcode&bootloader_20190625.zip)
2.1 Press “Esc” button on PC, power on BPI-M4 to enter boot command line.
2.2 Input “Realtek> usb start” to recognise udisk
2.3 Input “Realtek> fatload usb 0:1 0x01500000 bootloader.bin ” to load bootloader from udisk
2.4 Input “Realtek> chain 0x01500000 ” to install bootloader
3.Install Android Image (In bpi-m4_Android_8_1_system.zip)
3.1 Unzip bpi-m4_Android_8_1_system.zip, then copy these files in to udisk, then plug udisk on Bpi-M4
3.2 Reset Bpi-M4,enter to boot command line
3.3 Input “Realtek> usb start” to recognise udisk
3.4 Input “Realtek> fatload usb 0:1 0x02100000 rescue.emmc.dtb ” to load rescue.emmc.dtb from udisk
3.4 Input “Realtek> fatload usb 0:1 0x03000000 emmc.uImage ” to load emmc.uImage from udisk
3.5 Input “Realtek> fatload usb 0:1 0x02200000 rescue.root.emmc.cpio.gz_pad.img” to load rescue.root.emmc.cpio.gz_pad.img from udisk
3.6 Input “Realtek>fatload usb 0:1 0x0f900000 bluecore.audio.enc.A01” to load bluecore.audio.enc.A01 from udisk
3.7 Input “Realtek> boot k”, you will wait for around 5-10 mins, please do not operate during the debug console print log, it will reboot after this.
Development For Linux
Installed Docker
EMAC
Use iperf3 to test gmac
1. On PC Terminal:
  • Execute "iperf3 -s"
2. On M3 console:
You have two ways to setup BT
1. Use commands to setup BT
  • Execute "bluetoothctl"
  • Execute these commands:
2. Use UI interface to setup BT
WiFi on M4
  • ip link set wlan0 up
 network={
 ssid="ssid"
 psk="password"
 priority=1
  • dhclient wlan0
Docs
[1]
