Banana Pi BPI-M3
Revision as of 09:06, 15 August 2019 by Dangku (talk | contribs) (→Documents)
Overview: Allwinner A83T
Overview: front
Overview: back
BPI-M3 Premium Aluminum Enclosure
BPI-M3 acrylic case
BPI 4.0 OEM&ODM server Successful case : A83T Raid Nas design
BPI 4.0 OEM&ODM server Successful case : A83T Magic Mirror
  • Allwinner A83T Octa-core 1.8GHz Powerful CPU.
  • 2 GB LPDDR3 memory.
  • 8 GB eMMC storage.
  • HDMI out
  • IR control
  • WiFi & Bluetooth onboard.
  • MIPI DSI ingerface
  • CSI camera interface
Banana Pi BPI-M3
Remote IR Receiver (x1)
LED Power Status and 8P8C
Size & Weight 92x60mm, 48g
OS Android and Linux
40 PIN GPIO define of Banana pi BPI-M3
CON1-P02 DCIN
CON1-P03 TWI2-SDA PH5-EINT5
CON1-P04 DCIN
CON1-P05 TWI2-SCK PH4-EINT4
CON1-P07 S-PWM PL10-S-EINT10
CON1-P08 UART2-TX PB0-EINT0
CON1-P10 UART2-RX PB1-EINT1
CON1-P11 PC4 PC4
CON1-P12 UART2-CTS PB3-EINT3
CON1-P13 PC7 PC7
CON1-P15 PC17 PC17
CON1-P16 UART2-RTS PB2-EINT2
CON1-P18 PL8-ENT8 PL8-S-ENT8
CON1-P19 SPI0_MOSI PC0
CON1-P21 SPI0_MISO PC1
CON1-P23 SPI0_CLK PC2
CON1-P24 SPI0_CS PC3
CON1-P27 TWI1-SDA PH3-EINT3
CON1-P28 TWI1-SCK PH2-EINT2
CON1-P29 PC18 PC18
CON1-P36 PE5 PE5
CON1-P37 PE4 PE4
CON1-P38 OWA-DOUT PE18
CON1-P40 PE19 PE19
CN7-P01 IPSOUT
CN7-P02 AFVCC
CN7-P03 IPSOUT
CN7-P04 IOVDD
CN7-P05 GND
CN7-P06 GND
CN7-P07 CSI2-D3N
CN7-P08 AVDD-CSI
CN7-P09 CSI2-D3P
CN7-P10 DVDD-CSI-R
CN7-P11 GND
CN7-P12 NC
CN7-P13 CSI2-D2N
CN7-P14 CSI-RST-R PE16
CN7-P15 CSI2-D2P
CN7-P16 CSI-STBY-R PE17
CN7-P17 GND
CN7-P18 CSI-PCLK PE0
CN7-P19 CSI2-CKN
CN7-P20 CSI-MCLK PE1
CN7-P21 CSI2-CKP
CN7-P22 CSI-HSYNC PE2
CN7-P23 GND
CN7-P24 CSI-VSYNC PE3
CN7-P25 CSI2-D1N
CN7-P26 CSI-D9 PE13
CN7-P27 CSI2-D1P
CN7-P28 CSI-D8 PE12
CN7-P29 GND
CN7-P30 CSI-D7 PE11
CN7-P31 CSI2-D0N
CN7-P32 CSI-D6 PE10
CN7-P33 CSI2-D0P
CN7-P34 CSI-D5 PE9
CN7-P35 GND
CN7-P36 CSI-D4 PE8
CN7-P37 CSI-SCK PE14
CN7-P38 CSI-D3 PE7
CN7-P39 CSI-SDA PE15
CN7-P40 CSI-D2 PE6
Display specification
CN6-P01 VCC-MIPI
CN6-P02 IPSOUT
CN6-P03 VCC-MIPI
CN6-P04 IPSOUT
CN6-P05 GND
CN6-P06 IPSOUT
CN6-P07 GND
CN6-P08 IPSOUT
CN6-P09 NC
CN6-P10 GND
CN6-P11 NC
CN6-P12 DSI-D0N
CN6-P13 NC
CN6-P14 DSI-D0P
CN6-P15 NC
CN6-P16 GND
CN6-P17 TWI0-SDA PH1-EINT1
CN6-P18 DSI-D1N
CN6-P19 TWI0-SCK PH0-EINT0
CN6-P20 DSI-D1P
CN6-P21 TP-INT PL7-S-EINT7
CN6-P22 GND
CN6-P23 TP-RST PL6-S-EINT6
CN6-P24 DSI-CKN
CN6-P25 GND
CN6-P26 DSI-CKP
CN6-P27 LCD-BL-EN PD29
CN6-P28 GND
CN6-P29 LCD-RST PD26
CN6-P30 DSI-D2N
CN6-P31 LCD-PWR-EN PD27
CN6-P32 DSI-D2P
CN6-P33 GND
CN6-P34 GND
CN6-P35 LCD-PWM PD28
CN6-P36 DSI-D3N
CN6-P37 GND
CN6-P38 DSI-D3P
CN6-P39 AP-RESET#
CN6-P40 GND
CON2 P03 UART0-TXD PB9
CON2 P02 UART0-RXD PB10
CON2 P01 GND
Opnewrt
TinaLinux
BPI-M3 WIFI Lab test report : https://bananapi.gitbooks.io/bpi-m3/content/en/bpi-m3wifilabtest.html
BPI-M3 Validation test report : https://bananapi.gitbooks.io/bpi-m3/content/en/bpi-m3validationtest.html
BPI-M3 CE,FCC RoHS Certification : http://forum.banana-pi.org/t/bpi-m3-ce-fcc-rohs-certification/984
Android 5.1.1 V5
  • 2018-06-05 update
  • HDMI-Version
Google Drive : https://drive.google.com/open?id=1mLXOAH_LPT-uqtwWvgvJXw4Vo95tFr_z
Baidu Cloud : https://pan.baidu.com/s/1byqwqzz9SOIWHYfOabXKNw
  • LCD-Version
Google Drive : https://drive.google.com/open?id=1DAxQIws0eAVPAm0riH5HXc8M36SH_-sC
Baidu Cloud : https://pan.baidu.com/s/19l7a6Z75FuZb_f9Ls0fN5w
  • 2017-05-11 update
  • HDMI-Version
Google Drive : https://drive.google.com/open?id=0B_YnvHgh2rwjcXkxczlmOWxWV00
Baidu Cloud : https://pan.baidu.com/s/1pKF3Ggj
MD5: d7b7abf3443a49fb0f178ccf2f6e82d0
  • LCD-Version
Google Drive : https://drive.google.com/open?id=0B_YnvHgh2rwjSkM5NHFWYVdlakk
Baidu Cloud : https://pan.baidu.com/s/1mi2YOeG
MD5: b27dd45ac5fd1fd3b02db8ffd92c2871
  • 2018-07-18 BPI-M3 Ubuntu 16.04 Mate Desktop (new eMMC)
Features Map :http://wiki.banana-pi.org/M3_Image_Map#Ubuntu_16.04
Google Drive : https://drive.google.com/open?id=1DlOrt08yUY9hAETiUXBiyoyPFHrOxtvq
Baidu Drive : https://pan.baidu.com/s/1ND5QqoBevzM2TykwqZCkAA
forum pthread: http://forum.banana-pi.org/t/bananapi-bpi-m3-new-image-new-emmc-ubuntu16-04-debian9-release-2018-07-18/6294
  • 2018-07-18 M3 Ubuntu Server (new eMMC)
Features Map : http://wiki.banana-pi.org/M3_Image_Map#Ubuntu_Lite
Google Drive : https://drive.google.com/open?id=1Yyd2BepHjyhgXhSmnFh_0Az6YoXPEI3J
Baidu Drive : https://pan.baidu.com/s/10vSo0AmIiMrVLNPkQ63leQ
  • 2018-07-18 BPI-M3 Debian Jessie 9 (new eMMC)
Features Map : http://wiki.banana-pi.org/M3_Image_Map#Debian_Jessie_9
Google Drive : https://drive.google.com/open?id=1M997Uf-RVqdFKJkXMjgY0w3fHyiOq4iG
Baidu Drive : https://pan.baidu.com/s/1yQYG1iOEIrJADV_j-qvdwQ
Forum pthread : http://forum.banana-pi.org/t/bananapi-bpi-m3-new-image-new-emmc-ubuntu16-04-debian9-release-2018-07-18/6294
  • Armbian with 4.17.y for M3
Test build:http://ix.io/1fUK
Broken: wired, wireless network, Bluetooth, ...
Works: serial console, 8 cores, DVFS, USB, SATA, HDMI, DRM video driver, ...
image:https://forum.armbian.com/topic/474-banana-pi-m3/?do=findComment&comment=57400
Forum pthread:http://forum.banana-pi.org/t/armbian-with-4-17-y-for-m3/6174
Rasbian
  • 2018-5-28 update : Raspbian 8.0 V1.1
Image Link:
Google Drive: https://drive.google.com/open?id=1DSZru8UQRikI6pImLZIt1DmySVozy0FA
baidu cloud : https://pan.baidu.com/s/1Pz_6btHxj6F9w_6aw90Dww
Forum thread:
http://forum.banana-pi.org/t/banana-pi-bpi-m3-new-image-release-raspbian-jessie-8-0-2018-5-28-v1-1/5847
Arch Linux
  • 2018-08-19 ArchLinux-4.18.1-1-ARCH : Kernel: 4.18.1-1-ARCH U-Boot: 2018.09-rc1
U-Boot: 2018.09-rc1,Kernel: 4.18.1-1-ARCH,Ethernet works,Wifi works,HDMI works,LCD needs to be checked(I would appreciate if someone can check it),GPIO works(WiringPi),BPI tools included,I2C enabled(In TDB file)
source code on github : https://github.com/apankevych/BananaPi-M3-Linux-4.18.1-1-ARCH
download Image link:https://drive.google.com/file/d/1ia3JSmHH8ksia4e8doalUGSBHnytOgx4/view?usp=sharing
Forum pthread : http://forum.banana-pi.org/t/bananapi-bpi-m3-new-image-archlinux-4-18-1-1-arch-2018-08-19/6544
  • 2018-07-19 Arch Linux sunxi kernel-4.18-rc3 and uboot- 2018.01 thank Andriy_Pankevych do this great work.
Google drive : https://drive.google.com/open?id=1Ve91MG_7d1haawqqmiBo4qCugvF1iLyn
Source code: https://github.com/apankevych/BananaPi-M3-Linux-4.18.0-rc3
Forum pthread : http://forum.banana-pi.org/t/banana-pi-bpi-m3-new-image-arch-linux-sunxi-kernel-4-18-rc3-and-uboot-2018-01-2018-07-19/6312
FreeBSD
Simplenas
Lakka TV
Others image
