Getting Started with M2M
BPI-M2M
- 512MB DDR3 SDRAM
* Prepare 8G/above TF card, USB-Serial interface, PC with Ubuntu System * Using your USB-Serial Connect debug console on M2M![]()
Install Bpi tools
- apt-get install pv
Load your first Linux image on SD card
- you could download image from here
- after download image, copy it to your ubuntu PC
- plug your sd card to your ubuntu PC, and Execute "fdisk -l" to check the SD card drive letter
- Execute "bpi-copy xxx.img /dev/sd<drive letter>"
- Ex: my sd card is recognised as /dev/sdf
- I can use "bpi-copy xxx.img /dev/sdf" to install image on my SD card.
Compile code
After download code, execute "./build.sh" to compile it.
- ./build.sh
Update your image
Update rootfs & kernel
After we succeed to the code, Bootloader, kernel, rootfs will be generated in "SD" directory, then how to update the image?
- cd SD/bpi-m2m
Plug in your SD card to Ubuntu PC, then execute "fdisk -l" to check which /dev/sdX were generated by system
- bpi-update -c bpi-m2m.conf -d /dev/sde
Update boot
- cd 100MB
Execute "df -l" to check which /dev/sdX is "BPI-BOOT"
- df -l
- bpi-bootsel BPI-M2M-LCD7-8k.img.gz /dev/sd1
Make your own image
- Execute "bluetoothctl"
- Execute these commands:
network={
ssid="ssid"
psk="password"
priority=1
StartX
- apt-get install xorg
- apt-get install xserver-xorg
- apt-get install xinit
https://askubuntu.com/questions/518454/what-does-startx-command-do
NAS Application
1. Usb hub + sata to usb
- HDD is supported
- SSD is supported
We use HDF5640 camara.
BPI-Tools
Install Bpi-tools
Update Bpi-tools
- Execute "bpi-tools"
- cd /usr/local/bin
How to Update WiringPi
