Getting Started with M2 Zero
Revision as of 16:53, 28 June 2019 by Sinovoip (talk | contribs)
Overview: BPI-M2Z raspbian
Android 4.4
Ubuntu Linux
BPI-M2 Zero
  • 512MB SDRAM.
  • Mini HDMI.
Load your first image on M2 Zero
 * Here is the example: http://forum.banana-pi.org/t/bananapi-bpi-m2z-h2-new-image-raspbian-ubuntu-release-2018-07-09/6221
 * apt-get install pv
 4.After step 3, then you can insert your TF card into M2 Zero, and press power button setup M2 Zero
Update your image
 1.Clone M2Z repo: https://github.com/BPI-SINOVOIP/BPI-M2Z-bsp
 * git clone https://github.com/BPI-SINOVOIP/BPI-M2Z-bsp
 2.Build your project
 * ./build.sh BPI-M2Z-720P
 3.After finish built, Execute "cd SD", plug your Ubuntu TFcard in PC, then check your TFcard was recognised as /dev/sdX by Ubuntu.
 4. Execute "bpi-update -c bpi-m2z.conf -d /dev/sdX", to update the compiled kernel to your TFcard
How to create an image
  • Boot your SD card with M2 Zero, after M2 Zero finish starting, copy your files and config your system, then poweroff M2 Zero. [If you don't want to config your system, you can skip this step]
  • Execute "bpi-migrate -c bpi-m2z.conf -c ubuntu-mate-from-sd.conf -d /dev/sdx"
OTG
1. On M2 Zero console:
2. On PC terminal:
  • If adbd was succeed to set up, insert OTG-USB interface to M2 Zero and PC(with Ubuntu system)
  • Execute "adb devices" to see if PC has recognised M2 ZeroP OTG
  • If yes, we could execute "adb shell" to connect M2 Zero by adb now
USB Ethernet
  • Prepare a USB to OTG wire, usb ethernet adapter
  • Use iperf3 to test network
  • Execute "bluetoothctl"
  • Execute these commands:
  • ip link set wlan0 up
network={
ssid="ssid"
psk="password"
priority=1
  • dhclient wlan0
We use HDF5640 camara.
Display
parameters meaning:
BPI-Tools
Install Bpi-tools
Update Bpi-tools
  • Execute "bpi-tools"
  • cd /usr/local/bin
How to Update WiringPi
