Getting Started with W2
Read more: Banana Pi BPI-W2
Install Linux Image On W2
Install Image On SD Card On Windows
- English:
1.Format SD card: http://wiki.banana-pi.org/Quick_Start_Banana_pi_SBC#Format_your_SD_under_Windows_os
2.Install Image On SD Card: http://wiki.banana-pi.org/Quick_Start_Banana_pi_SBC#how_to_write_Linux_image
- Chinese:
https://www.cnblogs.com/topbin/p/10882992.html
Install Image On SD Card On Ubuntu
1.Install bpi-tools on your system * apt-get install pv * curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash 2.After you download the image, insert your TF card into your Ubuntu * Execute "bpi-copy xxx.img /dev/sdx" to install image on your TF card. 3.After step 2, then you can insert your TF card into W2, and press power button setup W2.
Install On EMMC
Load Android image on W2
Install On SD Card
Install On EMMC
Windows
- English
1.Format SD Card: http://wiki.banana-pi.org/Quick_Start_Banana_pi_SBC#Format_your_SD_under_Windows_os
GPIO
PWM Control
SATA
1. Mount dev on W2
- "mount /dev/sdx /mnt/xxx"
SSD
HDD
NetWork
- iperf3 -c [server]
- iperf3 -u -c [server]
- iperf3 -s
WiFi & BT
STA
network={
ssid="ssid"
psk="password"
priority=1
AP
Developing
Develop 4G module with W2
GPU
- glmark2 Score: 30
