Getting Started with W2
Overview: BPI-W2 Android 6.0
Debian 9 Linux Image Release 2018-09-18
BananaPI-W2 Ubuntu 18.04 New Image Release 2018-09-17
BananaPI-W2 Raspbian 9.4 New Image Release 2018-09-17
RPiTCv3_1.12-demo-bpi-w2-beta-2018-09-03
Read more: Banana Pi BPI-W2
  • Prepare 8G/above TF card, USB-Serial interface, PC with Ubuntu System
  • Using your USB-Serial Connect debug console on W2
Install Linux Image On W2
Install On SD Card
 * apt-get install pv
 4.After step 3, then you can insert your TF card into W2, and press power button setup W2.
Install On EMMC
Load Android image on W2
Install On SD Card
Install On EMMC
GPIO
PWM Control
SATA
1. Mount dev on W2
  • "mount /dev/sdx /mnt/xxx"
SSD
HDD
NetWork
  • iperf3 -c [server]
  • iperf3 -u -c [server]
  • iperf3 -s
WiFi & BT
STA
  • ip link set wlan0 up
network={
ssid="ssid"
psk="password"
priority=1
  • dhclient wlan0
AP
Developing
Develop 4G module with W2
GPU
  • Execute "glmark2-es" to start OpenGL test
  • glmark2 Score: 30
Make your own image
