Getting Started with M4
BPI-M4
File:M4 respbian.png
Overview: BPI-M4 respbian linux
  • 8G eMMC flash (max 64 GB)
  • USB 2.0 TYPE C
  • PoE function support
Development For Linux
Installed Docker
EMAC
Use iperf3 to test gmac
1. On PC Terminal:
  • Execute "iperf3 -s"
2. On M3 console:
You have two ways to setup BT 1. Use commands to setup BT
  • Execute "bluetoothctl"
  • Execute these commands:
File:M4 bluetooth.png
2. Use UI interface to setup BT
WiFi on M4
  • ip link set wlan0 up
 network={
 ssid="ssid"
 psk="password"
 priority=1
  • dhclient wlan0
