Getting Started with M4
BPI-M4
File:M4 respbian.png
Overview: BPI-M4 respbian linux
- Read more about : Banana Pi BPI-M4
- 8G eMMC flash (max 64 GB)
- USB 2.0 TYPE C
- PoE function support
Development For Linux
Installed Docker
EMAC
Use iperf3 to test gmac
1. On PC Terminal:
- Execute "iperf3 -s"
2. On M3 console:
WiFi on M4
network={
ssid="ssid"
psk="password"
priority=1
