Banana Pi BPI-M4
Revision as of 01:24, 28 February 2019 by Sinovoip (talk | contribs) (Introduction)
File:Banana pi BPI-M4 1.JPG
File:Banana Pi BPI-M4 3.JPG
Overview:Realtek RTD1395
PoE function support
M.2 and PCIE support
Banana Pi BPI-M4 use [ https://drive.google.com/file/d/1Jt8qUwEjLinMqURMftC3db0Xg9MIWIhu/view?usp=sharing Realtek RTD1395] chp design ,it is a 64-bit quad-core A53 mini single board computer. It features 1 GB of RAM and 8 GB eMMC. It also has onboard WiFi for b/g/n/ac and BT 4.2. On the ports side, the BPI-M4 has 4 USB 2.0 ports, 1 USB TYPE C port, 1 HDMI port, 1 audio jack. support M.2 Key E PCIE 2.0 interface.
  • 8G eMMC flash (max 64 GB)
  • USB 2.0 TYPE C
  • PoE function support
Getting Started with M4
Size & Weight 92x60mm, 48g
OS Android and Linux
CON1-P02 DCIN
CON1-P03 I2C1_SDA GPIO-17
CON1-P04 DCIN
CON1-P05 I2C1_SCL GPIO-16
CON1-P07 PWM1 GPIO-21
CON1-P08 UR1_TX GPIO-9
CON1-P10 UR1_RX GPIO-8
CON1-P11 SDIO-D0 GPIO-42
CON1-P12 AIO_BCK GPIO-3
CON1-P13 SDIO-D1 GPIO-43
CON1-P15 SDIO-D2 GPIO-44
CON1-P16 UR1_RTS GPIO-11
CON1-P18 UR1_CTS GPIO-10
CON1-P19 GSPI-MOSI GPIO-31
CON1-P21 GSPI-MISO GPIO-18
CON1-P22 GPIO-47 GPIO-47
CON1-P23 GSPI-SCK GPIO-19
CON1-P24 GSPI-CS GPIO-20
CON1-P26 PWM2 GPIO-22
CON1-P27 SDIO-D3 GPIO-45
CON1-P28 PWM3 GPIO-23
CON1-P29 SDIO-CLK GPIO-41
CON1-P31 SDIO-CMD GPIO-40
CON1-P32 SPDIF GPIO-50
CON1-P33 AIO_CK GPIO-4
CON1-P35 AIO_LRCK GPIO-2
CON1-P36 GPIO-53 GPIO-53
CON1-P37 GPIO-34 GPIO-34
CON1-P38 AI_SD GPIO-5
CON1-P40 AO_SD GPIO-6
CON2-P1 GND
CON2-P2 UART0-RX
CON2-P3 UART0-TX
documents
