2 ESPBlocks Beginner's only
Program with ESPBlocks
The development tools
Connect the board
  • Windows for example, in any location directly run, it is recommended that there is no Chinese path.
  • Double-click to open ESPblocks. Exe and wait for a moment while it releases the resource
  • Whether or not there is a Connect board, the Connect search board will pop up once, or you can click on the Connect to pop up the window.
  • Now we connect the board through the wire, it will automatically find the current connected board serial port and display, as shown in the figure below.
  • Then click the button in the figure to confirm that it is their own board can be connected.
  • the connection is completed as shown below:
  • Wireless connection is not supported now
Use the Editor to run the program
  • Prepare a piece of code and copy it into the white box.
print('\n')
print('test')
print('\n')
  • Click the Run button to complete the Run
Use Blockly to run the program
