Banana Pi BPI-M4
- Mali 470 MP4 GPU OpenGL ES 1.1/2.0
- 8G eMMC flash (max 64 GB)
- USB 2.0 TYPE C
- PoE function support
| HardWare Specification of Banana pi BPI-M4 | |||
| CPU | Realtek RTD1395 ARM Cortex-A53 Quad-Core 64 Bit | ||
| GPU | Mali 470 MP4 GPU OpenGL ES 1.1/2.0 | ||
| Memory | 1 GB DDR4 (option 2 GB) | ||
| Storage | MicroSD slot with support for up to 256GB expansion and 8G eMMC flash with support for up to 64GB | ||
| Network | 10/100 Mbit/s Ethernet + Wi-Fi 802.11 b/g/n/AC + Bluetooth 4.2 | ||
| Video Output(s) | 1080p capable HDMI port and multi-channel audio output (NO H./X.265 capabilities) | ||
| Audio Output(s) | 3.5mm jack and HDMI | ||
| PCIE | M.2 Key E slot PCIE 2.0 and USB 2.0 | ||
| USB ports | USB 2.0 PORT (x4), USB 2.0 TYPE C(x1) | ||
| Power Source | 5 volt @2A via Micro USB (TYPE C) or PoE support | ||
| OS | Android and Linux | ||
| 40 PIN GPIO of Banana pi BPI-M4 | |||||||||
| GPIO Pin Name | Default Function | Function2:GPIO | Function3 | CON1-P01 | VCC-3V3 | ||||
| CON1-P02 | DCIN | ||||||||
| CON1-P03 | I2C1_SDA | GPIO-17 | |||||||
| CON1-P04 | DCIN | ||||||||
| CON1-P05 | I2C1_SCL | GPIO-16 | |||||||
| CON1-P06 | GND | ||||||||
| CON1-P07 | PWM1 | GPIO-21 | |||||||
| CON1-P08 | UR1_TX | GPIO-9 | |||||||
| CON1-P09 | GND | ||||||||
| CON1-P10 | UR1_RX | GPIO-8 | |||||||
| CON1-P11 | SDIO-D0 | GPIO-42 | |||||||
| CON1-P12 | AIO_BCK | GPIO-3 | |||||||
| CON1-P13 | SDIO-D1 | GPIO-43 | |||||||
| CON1-P14 | GND | ||||||||
| CON1-P15 | SDIO-D2 | GPIO-44 | |||||||
| CON1-P16 | UR1_RTS | GPIO-11 | |||||||
| CON1-P17 | VCC-3V3 | ||||||||
| CON1-P18 | UR1_CTS | GPIO-10 | |||||||
| CON1-P19 | GSPI-MOSI | GPIO-31 | |||||||
| CON1-P20 | GND | ||||||||
| CON1-P21 | GSPI-MISO | GPIO-18 | |||||||
| CON1-P22 | GPIO-47 | GPIO-47 | |||||||
| CON1-P23 | GSPI-SCK | GPIO-19 | |||||||
| CON1-P24 | GSPI-CS | GPIO-20 | |||||||
| CON1-P25 | GND | ||||||||
| CON1-P26 | PWM2 | GPIO-22 | |||||||
| CON1-P27 | SDIO-D3 | GPIO-45 | |||||||
| CON1-P28 | PWM3 | GPIO-23 | |||||||
| CON1-P29 | SDIO-CLK | GPIO-41 | |||||||
| CON1-P30 | GND | ||||||||
| CON1-P31 | SDIO-CMD | GPIO-40 | |||||||
| CON1-P32 | SPDIF | GPIO-50 | |||||||
| CON1-P33 | AIO_CK | GPIO-4 | |||||||
| CON1-P34 | GND | ||||||||
| CON1-P35 | AIO_LRCK | GPIO-2 | |||||||
| CON1-P36 | GPIO-53 | GPIO-53 | |||||||
| CON1-P37 | GPIO-34 | GPIO-34 | |||||||
| CON1-P38 | AI_SD | GPIO-5 | |||||||
| CON1-P39 | GND | ||||||||
| CON1-P40 | AO_SD | GPIO-6 | |||||||
BPI-M4 Debug UART(CON2) CON2-P1 GND CON2-P2 UART0-RX CON2-P3 UART0-TX
