Getting Started with P2-Zero
- Read more about : Banana Pi BPI-P2 Zero
BPI-P2 Zero
- CPU: Allwinner H2+, Quad-core Cortex-A7
- 512MB DDR 3 SDRAM
- Mini HDMI
- 40 PIN GPIO, It includes UART, SPI, I2C, IO etc
- 100M LAN
- 8G eMMC flash onboard
* Using your USB-Serial Connect debug console on P2 Zero
Load your first image on M2 Zero
1.You could download latest image from our forum * Here is the example: http://forum.banana-pi.org/t/bananapi-bpi-m2z-h2-new-image-raspbian-ubuntu-release-2018-07-09/6221 2.Install bpi-tools on your system * apt-get install pv * curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash 3.After you download the image, insert your TF card into your Ubuntu * Execute "bpi-copy xxx.img /dev/sdx" to install image on your TF card. 4.After step 3, then you can insert your TF card into M2 Zero, and press power button setup M2 Zero
Update your image
1.Clone M2Z repo: https://github.com/BPI-SINOVOIP/BPI-M2Z-bsp * git clone https://github.com/BPI-SINOVOIP/BPI-M2Z-bsp
2.Build your project * ./build.sh BPI-M2Z-720P
3.After finish built, Execute "cd SD", plug your Ubuntu TFcard in PC, then check your TFcard was recognised as /dev/sdX by Ubuntu. 4. Execute "bpi-update -c bpi-r2.conf -d /dev/sdX", to update the compiled kernel to your TFcard
How to create an image
OTG
1. On M2 Zero console:
2. On PC terminal:
USB Ethernet
- Use iperf3 to test network
- Execute "bluetoothctl"
- Execute these commands:
network={
ssid="ssid"
psk="password"
priority=1
We use HDF5640 camara.
Display
parameters meaning:
BPI-Tools
Install Bpi-tools
Update Bpi-tools
- Execute "bpi-tools"
- cd /usr/local/bin
How to Update WiringPi
