BPI-Bit
Revision as of 09:05, 5 May 2018 by Sinovoip (talk | contribs)
The BPI-bit (also referred to as BPI:bit, stylised as webduino:bit) is an ESP32 with Xtensa 32bit LX6 single/dual-core processor based embedded system
BPI:bit hardware
BPI:bit interface
