Getting Started with R64
Read more: Banana Pi BPI-R64
  • 1G DDR3 SDRAM
  • Built-in 4x4n 802.11n/Bluetooth 5.0 system-on-chip
  • MTK7615 4x4ac wifi on board
  • Support 1 SATA interface
  • 1 Port USB 3.0
  • POE function support
 * Using your USB-Serial Connect debug console on R64
Load your first image on R64
 * apt-get install pv
 4.After step 3, then you can insert your TF card into R64, and press power button to setup R64
Ubuntu On Emmc
 1. If you want to install image on EMMC, follow these steps:
 * Burn an image to sd card, and set up R64 with sd card.
 * Copy the image which name contains "xxx-emmc-xxx" to U disk.
 * mount U disk to R64, then use bpi-copy to burn image to Emmc.
   bpi-copy  <XXX.img.zip>
 * After this, reboot R64.
 * Remove SD & power on.
Network-Configuration
GPIO
  • echo 431(22+409) > /sys/class/gpio/export
  • echo out > /sys/class/gpio/gpio431/direction
  • echo 1 > /sys/class/gpio/gpio431/value
PWM Control
Sata
  • If you want to use Sata interface on R64, you need to give GPIO90 low level
    • echo 499 > /sys/class/gpio/export
    • echo out > /sys/class/gpio/gpio499/direction
    • echo 0 > /sys/class/gpio/gpio499/value
  • Test a TOSHIBA HDD DISK, the Read/Write performance are below:
Read from disk: 50MB/s command: dd if=/dev/sda of=/dev/null bs=1M count=1024
Write to disk: 38MB/s command: dd if=/dev/zero of=/dev/sda bs=1M count=1024
Read from disk: 360MB/s command: dd if=/dev/sda of=/dev/null bs=1M count=1024
Write to disk: 200MB/s command: dd if=/dev/zero of=/dev/sda bs=1M count=1024
PCIe
  • If you want to use PCIe interface on R64, you need to give GPIO90 high level
    • echo 1 > /sys/class/gpio/gpio499/value
  • PCIe supports EC-25 4G module.
Use iperf3 to test gmac
1. On PC Terminal:
  • Execute "iperf3 -s"
2. On R64 console:
BT & BLE on R64
R64 BT Architectural
  • BT on R64
  • BLE on R64
    • MW_GAP name 7622_BT /*rename bt device*/
    • MW_GAP info /*check local BT device info*/
    • MW_GATTC scan /* start ble scan*/
    • MW_GATTC stop_scan /* stop ble scan*/
WiFi and Ap mode on R64
  • Find "mt_wifi.ko" and insmod it.
    • insmod ./lib/modules/4.4.92-BPI-R64-Kernel/extra/mt_wifi.ko
  • Then you will see
  • wmt_loader (ignore errors)
  • ip link set wlan0 up
 network={
 ssid="ssid"
 psk="password"
 priority=1
  • dhclient wlan0
AP mode
  • echo A >/dev/wmtWifi
 interface=ap0
 bridge=br0
 ssid=test_r2
 driver=nl80211
 country_code=US
 hw_mode=b
 channel=1
 max_num_sta=5
 wpa=2
 auth_algs=1
 rsn_pairwise=CCMP
 wpa_key_mgmt=WPA-PSK
 wpa_passphrase=ledetest
 logger_stdout=-1
 logger_stdout_level=2
  • And a bridge
  • brctl addbr br0
  • brctl addif br0 ap0
  • brctl addif br wan
Reference Link
http://forum.banana-pi.org/
