Banana Pi BPI-M64
Banana Pi BPI-M64 is a 64-bit quad-core mini single board computer. It features 2GB of RAM and 8GB eMMC. It also has onboard WiFi and BT. On the ports side, the BPI-M64 has 2 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, and lastly a DC power port. The processor is pin-to-pin comptialbe with R18, so it comes with two versions:M64 and M64-R18.
  • Allwinner A64 1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor.
  • 2 GB DDR3 SDRAM
  • 8G EMMC
  • 10/100/1000Mbps Ethernet
  • WiFi (AP6212) & Bluetooth
Banana Pi M64
CPU Allwinner A64 64 bit Quad Core ARM Cortex A53 1.2 GHz CPU
GPU Dual core Mali 400 MP2 GPU
Storage MicroSD slot supports up to 256GB expansion & 8 G eMMC flash (option 16/32/64G)
Network 10/100/1000 Mbit/s Ethernet + Wi-Fi 802.11 b/g/n + Bluetooth BT4.0
Video Output(s) high-definition video playback & 2K HDMI port and multi-channel audio output (NO H./X.265 capabilities)
Remote IR Receiver (x1)
LED Power Status and 8P8C
Size & Weight 92x60mm, 48g
OS Android and Linux
40 PIN GPIO of Banana pi BPI-M64
CON2-P01 VCC-3V3
CON2-P02 VCC-5V
CON2-P03 TWI1-SDA PH3
CON2-P04 VCC-5V
CON2-P05 TWI1-SCK PH2
CON2-P06 GND
CON2-P07 PH6 PH6
CON2-P08 UART2-TX PB0
CON2-P09 GND
CON2-P10 UART2-RX PB1
CON2-P11 PH7 PH7
CON2-P12 UART2-CTS PB3
CON2-P13 DMIC-CLK PH10
CON2-P14 GND
CON2-P15 DMIC-DIN PH11
CON2-P16 UART2-RTS PB2
CON2-P17 VCC-3V3
CON2-P18 PD4 PD4
CON2-P19 SPI1-MOSI PD2 UART4-TX
CON2-P20 GND
CON2-P21 SPI1-MISO PD3 UART4-RX
CON2-P22 PC0 PC0
CON2-P23 SPI1-CLK PD1 UART3-RX
CON2-P24 SPI1-CS PD0 UART3-TX
CON2-P25 GND
CON2-P26 PC2 PC2
CON2-P27 PC4 PC4
CON2-P28 PC3 PC3
CON2-P29 PC7 PC7
CON2-P30 GND
CON2-P31 PCM0-BCLK PB5
CON2-P32 PCM0-DIN PB7
CON2-P33 PCM0-SYNC PB4
CON2-P34 GND
CON2-P35 PCM0-DOUT PB6
CON2-P36 PL9 PL9
CON2-P37 PL12 PL12
CON2-P38 PL7 PL7
CON2-P39 GND
CON2-P40 PL8 PL8
CSI camer PIN define of Banana pi BPI-M64
Default Function| Function2:GPIO| -- | NC|   GND|   CSI0-SDA| PE13| CSI0-AVDD|   CSI0-SCK| PE12| CSI0-Reset| PE16| CSI0-VSYNC| PE3| CSI0-PWDN| PE17| CSI0-HSYNC| PE2| CSI0-DVDD|   CSI0-DOVDD|   CSI0-D7| PE11| CSI0-MCLK| PE1| CSI0-D6| PE10| GND|   CSI0-D5| PE9| CSI0-PCLK| PE0| CSI0-D4| PE8| CSI0-D0| PE4| CSI0-D3| PE7| CSI0-D1| PE5| CSI0-D2| PE6| GND |  CSI0-AFVCC
MIPI DSI display PIN define of Banana pi BPI-M64
Default Function| Function2:GPIO| -- | VCC |  IPSOUT|   VCC |  IPSOUT|   GND|   IPSOUT |  GND   IPSOUT |  NC |  GND   NC |  DSI-D0N   NC |  DSI-D0P   NC |  GND   TWI0-SDA| PH1| DSI-D1N |  TWI0-SCK| PH0| DSI-D1P   CTP-INT| PH4| GND|   CTP-RST| PH8| DSI-CKN |  GND   DSI-CKP |  LCD-BL-EN| PD5| GND   LCD-RST |PD6| DSI-D2N |  LCD-PWR-EN |PD7| DSI-D2P |  GND   GND |  LCD-PWM| PL10| DSI-D3N   GND   DSI-D3P |  NC   GND
Uart PIN define of Banana pi BPI-M2+
Default Function| GPIO| -- | UART0-TXD| PB8| UART0-RXD| PB9| GND |
Opnewrt
TinaLinux
Release
