香蕉派 BPI-M2 Ultra
Banana PI BPI-M2 Ultra
Overview: BPI-M2 with R40 chip
Overview: BPI-M2 with A40i chip
Overview: BPI-M2 with V40 chip
File:M2 M64 Ultra case 3.JPG
BPI-M2 Ultra Premium Aluminum Enclosure
BPI-M2 Ultra acrylic case
BPI-M2 Ultra for BPI 4.0 Successful case :R40 for vehicle license plate recognition
BPI-M2 Ultra for BPI 4.0 Successful case :R40 for IoT gateway with Z-wave, zigbee,WiFI
香蕉派 BPI-M2 Ultra 四核单板计算机采用全志 R40芯片开发。支持板载Wifi与蓝牙,支持SATA接口,可以直接接硬盘。并且板载8G eMMC ,可以选择SD卡启动或从eMMC flash 启动。
Banana PI BPI-M2 Ultra 兼容性强大,可以跑android系统,Debian linux,Ubuntu linux, Raspberry Pi系统 和 全志Tina 系统.
Banana PI BPI-M2 Ultra硬件:全志R40 四核处理器,2GB LPDDR3内存,千兆以太网口,3USB 接口 流畅运行Android5.1。Banana PI BPI-M2 Ultra 体积如信用卡大小,与BPI-M3尺寸一样,GPIO兼容Raspberry PiB+并能运行其ROM Image。
File:BPI-M2 Ultra a.JPG
  • 全志R40/V40 Quad Core ARM Cortex A7 CPU
  • 2GB DDR3 SDRAM.
  • 8GB eMMC flahs onboard.
  • SATA Interface.
  • 2*USB 2.0
  • MIPI DSI ingerface
  • CSI camera interface
开始使用
硬件接口图
File:BPI-M2 Ultra interface.jpg
香蕉派 BPI-M2 Ultra硬件规格书
主芯片 Allwinner R40/V40
CPU主控 quad-core cortex -A7,the most power efficient CPU core ARM's ever development
SDRAM内存 2 GB DDR3 with 733MHz\(shared with GPU\)
SATA 硬盘接口 suppoort SATA interface
GPIO定义 40 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S.
有线网口 10/100/1000Mbps Ethernet \(Realtek RTL8211E/D\)
Wifi 无线 WiFi 802.11 b/g/n \(AP 6212 module on board\)
蓝牙支持 BT4.0
Flash存储 MicroSD \(TF\) card,8GB eMMC onboard
显示 4-lane MIPI DSI display,or RGB panel or LVDS panel,TV-out on HDMI V1.4
Audio outputs HDMI, analog audio \(via 3.5 mm TRRS jack\)
Camera摄像头 A CSI input connector Camera:Supports 8-bit YUV422 CMOS sensor interface,Supports CCIR656 protocol for NTSC and PAL,Supports 5M pixel camera sensor ,Supports video capture solution up to 1080p@30fps
USB 2 USB 2.0 host, 1 USB 2.0 OTG
按键 Reset button, Power button, U-boot button
Led 灯 Power status Led and RJ45 Led
IR红外控制 onboard IR receiver
DC 供电 5V/2A with micro USB port
电池接口 3.7V lithium battery power support
尺寸 85mmX56mm,same size as raspberry pi 3
Weight 40g
GPIO PIN 定义
香蕉派BPI-M2 Ultra 支持40-pin GPIO 接口,定义兼容树莓派3. GPIO定义如下:
香蕉派BPI-M2 Ultra 40-pin GPIO 接口定义
CON1-P02 DCIN
CON1-P03 TWI2-SDA PB21 PWM5
CON1-P04 DCIN
CON1-P05 TWI2-SCK PB20 PWM4
CON1-P07 PB3 PB3 PWM1
CON1-P11 UART7-TX PI20 PWM2
CON1-P13 UART7-RX PI21 PWM3
CON1-P15 PH25 PH25 CSI1-FIELD
CON1-P18 PH26 PH26 CSI1-HSYNC
CON1-P19 SPI0\_MOSI PC0
CON1-P21 SPI0\_MISO PC1
CON1-P22 PH27 PH27 CSI1-VSYNC
CON1-P23 SPI0\_CLK PC2
CON1-P24 SPI0\_CS PC23
CON1-P26 PH24 PH24 CSI1-PCLK
CON1-P27 TWI3-SDA PI1
CON1-P28 TWI3-SCK PI0
CON1-P29 PH0 PH0 CSI1-D0
CON1-P31 PH1 PH1 CSI1-D1
CON1-P32 PD20 PD20 CSI1-MCLK
CON1-P33 PH2 PH2 CSI1-D2
CON1-P35 PH3 PH3 CSI1-D3
CON1-P36 UART5-RX PH7 CSI1-D7
CON1-P37 UART4-TX PH4 CSI1-D4
CON1-P38 UART5-TX PH6 CSI1-D6
CON1-P40 UART4-RX PH5 CSI1-D5
CSI Camera 摄像头接口规格:
BPI-M2 Ultra CSI 摄像头 GPIO 定义
CN5-P01 NC
CN5-P02 GND
CN5-P03 CSI0-SDA PI3
CN5-P04 CSI0-AVDD
CN5-P05 CSI0-SCK PI2
CN5-P06 CSI0-Reset PI7
CN5-P07 CSI0-VSYNC PE3
CN5-P08 CSI0-PWDN PI6
CN5-P09 CSI0-HSYNC PE2
CN5-P10 CSI0-DVDD
CN5-P11 CSI0-DOVDD
CN5-P12 CSI0-D7 PE11
CN5-P13 CSI0-MCLK PE1
CN5-P14 CSI0-D6 PE10
CN5-P15 GND
CN5-P16 CSI0-D5 PE9
CN5-P17 CSI0-PCLK PE0
CN5-P18 CSI0-D4 PE8
CN5-P19 CSI0-D0 PE4
CN5-P20 CSI0-D3 PE7
CN5-P21 CSI0-D1 PE5
CN5-P22 CSI0-D2 PE6
CN5-P23 GND
CN5-P24 CSI0-AFVCC
MIPI屏显示接口规格
CN6-P01 VCC-3V3
CN6-P02 IPSOUT
CN6-P03 VCC-3V3
CN6-P04 IPSOUT
CN6-P05 GND
CN6-P06 IPSOUT
CN6-P07 GND
CN6-P08 IPSOUT
CN6-P09 NC
CN6-P10 GND
CN6-P11 NC
CN6-P12 DSI-D0N
CN6-P13 NC
CN6-P14 DSI-D0P
CN6-P15 NC
CN6-P16 GND
CN6-P17 TWI0-SDA PB19
CN6-P18 DSI-D1N
CN6-P19 TWI0-SCK PB18
CN6-P20 DSI-D1P
CN6-P21 CTP-INT PI10
CN6-P22 GND
CN6-P23 CTP-RST PI11
CN6-P24 DSI-CKN
CN6-P25 GND
CN6-P26 DSI-CKP
CN6-P27 LCD-BL-EN PH16
CN6-P28 GND
CN6-P29 LCD-RST PH17
CN6-P30 DSI-D2N
CN6-P31 LCD-PWR-EN PH18
CN6-P32 DSI-D2P
CN6-P33 GND
CN6-P34 GND
CN6-P35 LCD-PWM PB2
CN6-P36 DSI-D3N
CN6-P37 GND
CN6-P38 DSI-D3P
CN6-P39 NC
CN6-P40 GND
CON2 P03 UART0-TXD
CON2 P02 UART0-RXD
CON2 P01 GND
软件
基本开发
Allwinner V40 datasheet
Allwinner R40 datasheet
axp221s PMU datasheet
  • Banana pi BPI-M2 Ultra CE,FCC,RoHS
BPI-M2 Ultra WIFI&BT4.0 Lab test
BPI-M2 Ultra validation test report
CE FCC RoHS
Android 6.0
  • 2017-08-25 update
  • HDMI-Version
  • LCD5-Version
  • LCD7-Version
3.10 kernel
  • 2017-11-13 update
Rasbian
Google Drive :https://drive.google.com/open?id=1Ntdh5tMyCjiAu8bBC9NC2ShEAYAAD0tD
Boot logs : http://ix.io/1kVQ
Tina IoT Linux
more please see : Tina Linux
RPiTC v3 1.12
  • 2017-11-28 updtae
Others
