Banana Pi 开源路由器产品系列比较表
| Banana Pi 开源路由器产品系列比较表 | |||||
| 产品型号 | Banana Pi BPI-R1 | Banana Pi BPI-R2 | Banana Pi BPI-W2 | Banana Pi BPI-R64 | |
| 产品图片 | File:BPI-R64 1.JPG banana Pi BPI-R64 |
| CPU主控 | Allwinner A20,32 Bit Cortex™-A7 2-Core 1G | MTK MT7623N, 32 Bit Cortex™-A7 4-Core 1.3GHz | Realtek RTD1296 64 Bit quad-core ARM A53 | MediaTek MT7622,1.35GHZ 64 bit dual-core ARM Cortex-A53 | |
| GPU | ARM® Mali400MP2 | ARM® Mali450 MP4 | Mali T820 MP3 GPU | N/A | |
| SDRAM内存 | 1GB DDR3 (shared with GPU) 432Mhz | 2GB DDR3 (shared with GPU) 1600Mhz | 2GB DDR4 \(shared with GPU\) | 1G DDR3 | |
| 存储 | "SD Card up to 64GB (SDXC) 1 SATA up to 2TB " | "MicroSD (TF) card (UHS-1) 2 SATAIII 6Gbps EMMC 4.5 8GB " | "MicroSD (TF) card (UHS-1) 2 SATAIII 6Gbps EMMC 4.5 8GB " | "MicroSD (TF) card (UHS-1) 1 SATAIII 6Gbps EMMC 4.5 8GB " | |
| 有线网口 | 4x Gigabit LAN 1x Gigabit WAN | 4x Gigabit LAN 1x Gigabit WAN (MT7530) | 1x Gigabit LAN 1x Gigabit WAN | 4x Gigabit LAN 1x Gigabit WAN | |
| WIFI无线 | 802.11b/g/n (RTL8192CU) | "802.11a/b/g/n & BT4.1 (MT6625L) 802.11ac moudle Wi-Fi 4x4 (MT7615 option)" | N/A | built-in 4x4n 802.11n/Bluetooth 5.0 system-on-chip and MTK7615 4x4ac wifi on board | |
| Vidio In | CSI input for video cameras | NA | HDMI in | N/A | |
| Video Out | HDMI/LVDS/RGB | HDMI/MIPI | HDMI/ MIPI DP | N/A | |
| Audio Output | 3.5 mm Jack and HDMI out | HDMI out & I2S | HDMI out, I2S audio,Audio micro out | N/A | |
| Audio In | Microphone | N/A | 2 MIC in and HDMI in | N/A | |
| USB 2.0 | 2 USB 2.0 ports, 1 OTG microUSB port | 1 USB 2.0 OTG | 2x USB 2.0 OTG :1 with standard USB port , 1 define with PIN | N/A | |
| USB 3.0 | N/A | 2xUSB 3.0 | 1xUSB 3.0 | 1xUSB 3.0 | |
| HDMI in | N/A | N/A | 1 HDMI in | N/A | |
| TYPE C | N/A | N/A | 1x TYPE C | N/A | |
| Mini DP | N/A | N/A | 1x Mini DP | N/A | |
| PCIE | N/A | 1* mini PCIE,1*pcie with 14 PIN define | 1xM.2 KEY B : USB 2.0 for 4G with Micro SIM card slot ;2xM.2 KEY E:1 with PCIE 2.0/USB 2.0,1 with 1 pcie 1.1/SDIO/USB 2.0 interface | 1* mini PCIE | |
| GPIO 40-PIN | GPIO, UART, I²C bus,I²S bus,SPI bus with two chip selects, CAN bus, PWM,+3.3 V, +5 V, ground | 40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. | 40 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S. | 40 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S. | |
| Power Source | 5 volt via MicroUSB and/or MicroUSB (OTG) | 12 volt via DC In | 12 volt via DC In | 12 volt via DC In | |
| Buttons | Reset button Power button, Uboot button | Reset button Power button, Uboot button | Reset button Power button, Uboot button | Recovery buton | |
| LED | Power key and RJ45 | Power key and RJ45 | Power key and RJ45 | Power status Led and RJ45 Led | |
| Remote | IR reciever | IR reciever | IR reciever | N/A | |
| Board Size | 120mm ×100mm | 120mm ×100mm | 120mm ×100mm | 120mm ×100mm | |
| Weight | 60g | 60g | 60g | 100g | |
| OS | Android and Linux OS OpenWRT | Android and Linux OS OpenWRT | Android and Linux OS OpenWRT | Linux OS OpenWRT | |
- All banana pi:
