快速上手 M2 Ultra & Berry
BPI-M2U
Overview: BPI-M2U respbian linux
  香蕉派 BPI-M2 Ultra 搭载4核 AllWinner R40处理器, 板载 2Gb内存和 8GbEmmc, 另外还搭载了WiFi和蓝牙模块, 接口方面, BPI-M2 Ultra 具备 2口USB 2.0, 1口 USB Otg, 1口HDMI, SATA 和 音频接口等.
  • Quad Core ARM Cortex A7 CPU R40
  • 2GB DDR3 SDRAM
  • 8 GB eMMC storage
  • SATA Interface
BPI-M2 Berry
  香蕉派 BPI-M2 Berry 搭载4核 AllWinner V40处理器, 板载 1Gb内存和 8GbEmmc, 另外还搭载了WiFi和蓝牙模块, 接口方面, BPI-M2 Ultra 具备 2口USB 2.0, 1口 USB Otg, 1口HDMI, SATA 和 音频接口等.
  • Quad Core ARM Cortex A7 CPU V40.
  • 1GB DDR3 SDRAM.
  • SATA Interface
基础开发
开发前准备
 * 准备一张容量不低于8Gb的TF卡, USB-Serial 串口线, 一台运行Ubuntu系统的PC机
 * 使用你的串口线去连接M2U的调试串口
烧录第一个Linux镜像到 M2U
 1.你可以从下面链接下载最近的镜像
 * http://forum.banana-pi.org/t/banana-pi-bpi-m2u-berry-new-image-release-raspbian-jessie-8-0-2018-5-24/5812
 2.在你的Ubuntu系统电脑上安装bpi-tools, 执行以下命令即可安装:
 * apt-get install pv
 3.下载完镜像后, 插入TF卡到你的Ubuntu电脑中
 * 运行命令 "bpi-copy xxx.img /dev/sdx" 烧录镜像到你的TF卡中.
 4.烧录完成后, 把TF卡插到M2U中, 按住M2U的电源键启动M2U.
Load your first image on M2U EMMC
 * Run your M2U with TF card
 * Plug your USB disk in M2U
 * After M2U recognise USB disk, execute "bpi-copy xxx-sd-emmc-xxx.img.zip / xxx-sd-emmc-xxx.img" to install image on EMMC
 * Then power off M2U, take TF card out, power on M2U
How to build uboot & kernel
Install tools
Clone code
SATA
1. Mount SATA on M2U
  • "mount /dev/sdx /mnt/xxx"
OTG
1. On M2U console:
2. On PC terminal:
  • If adbd was succeed to set up, insert OTG-USB interface to M2U and PC(with Ubuntu system)
  • Execute "adb devices" to see if PC has recognised M2U OTG
  • If yes, we could execute "adb shell" to connect M2U by adb now
LCD 5" & LCD 7"
  • Find "BPI_M2U_LCD7.img.gz"
  • Then execute "bpi-bootsel /usr/lib/u-boot/bananapi/bpi-m2u/BPI_M2U_LCD7.img.gz"
Touch screen
Use iperf3 to test gmac
1. On PC Terminal:
  • Execute "iperf3 -s"
2. On M2U console:
  • Execute "bluetoothctl"
  • Execute these commands:
WiFi on M2U
  • ip link set wlan0 up
  • dhclient wlan0
We use HDF5640 camara.
IR function
  • Execute "getevent"
  • Use your IR device to send information to M2U
WringPi
File System
Install Qt5.7 & Qtcreator
1.Prepare a 32Gb TF card
2.Use GParted to resize root point '/' as 32Gb
3.apt-get install libxcb*
4.download qt5.7
5.make & make install
6.apt-get install qtcreator
7.Config qtcreator
Reference Link
