Banana Pi BPI-M64
Banana Pi BPI-M64 is a 64-bit quad-core mini single board computer. It features 2GB of RAM and 8GB eMMC. It also has onboard WiFi and BT. On the ports side, the BPI-M64 has 2 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, and lastly a DC power port. The processor is pin-to-pin comptialbe with R18, so it comes with two versions:M64 and M64-R18.
- Allwinner A64 1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor.
- 2 GB DDR3 SDRAM
- 8G EMMC
- 10/100/1000Mbps Ethernet
- WiFi (AP6212) & Bluetooth
| Banana Pi M64 | |
| CPU | Allwinner A64 64 bit Quad Core ARM Cortex A53 1.2 GHz CPU |
| GPU | Dual core Mali 400 MP2 GPU |
| Memory | 2 GB LPDDR3 (shared with GPU) |
| Storage | MicroSD slot supports up to 256GB expansion & 8 G eMMC flash (option 16/32/64G) |
| Network | 10/100/1000 Mbit/s Ethernet + Wi-Fi 802.11 b/g/n + Bluetooth BT4.0 |
| Video Input(s) | A CSI input connector allows for the connection of a designed camera module |
| Video Output(s) | high-definition video playback & 2K HDMI port and multi-channel audio output (NO H./X.265 capabilities) |
| Audio Input(s) | On board microphone |
| Audio Output(s) | 3.5mm jack and HDMI |
| USB ports | USB 2.0 PORT (x2), USB OTG (x1) |
| Remote | IR Receiver (x1) |
| Switches | Reset, Power and U-boot |
| Size & Weight | 92x60mm, 48g |
| OS | Android and Linux |
| 40 PIN GPIO of Banana pi BPI-M64 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
GPIO Pin Name| Default Function|Function2:GPIO|Function3| |
-- | | VCC-3V3 | VCC-5V | TWI1-SDA| PH3| | VCC-5V | TWI1-SCK| PH2| | GND | PH6| PH6| | UART2-TX| PB0| | GND | UART2-RX| PB1| | PH7| PH7| | UART2-CTS| PB3 | | DMIC-CLK| PH10| | GND | DMIC-DIN| PH11| | UART2-RTS| PB2| | VCC-3V3 | PD4| PD4 | | SPI1-MOSI| PD2| UART4-TX| | GND | SPI1-MISO| PD3| UART4-RX| | PC0| PC0| | SPI1-CLK| PD1| UART3-RX| | SPI1-CS |PD0| UART3-TX| | GND | PC2| PC2 | PC4| PC4 | PC3| PC3 | PC7| PC7 | GND | PCM0-BCLK| PB5 | PCM0-DIN| PB7 | | PCM0-SYNC| PB4 | | GND | PCM0-DOUT| PB6 | PL9| PL9 | | PL12| PL12| | PL7| PL7 | | GND | PL8| PL8 |
