Banana Pi BPI-W2
Revision as of 03:37, 21 September 2018 by Sinovoip (talk | contribs) (Documents)
  • Mali T820 MP3 GPU
  • 2G DDR4 SDRAM
  • 8G eMMC flash
  • 2xMIC int/Audio out
  • 2 SATA interface
  • 1XGigabit LAN 1x Gigabit WAN
  • 1xUSB 3.0 2xUSB 2.0
  • HDMI in & HDMI out
  • Mini DP
  • TYPE C
HardWare Specification of Banana pi BPI-W2
Soc Realtek RTD1296 quad-core ARM A53
GPU Mali T820 MP3 GPU
Power 12V @ 2A via DC power 5.0mmx2.0mm jack
Wifi/Bluetooth **Option** ,not support onboard WIFI & BT
On board Storage MicroSD \(TF\) card; 2 native SATA 3 6Gbps ;eMMC;SIM card slot
Display HDMI \(Type A\) output with HDCP 1.4, resolutions up 1920x1200; MIPI DP
HDMI Out/In 1* HDMI 2.0a out port and 1* HDMI 2.0a In port
USB 3.0 1x USB 3.0 host
Mini DP 1* Mini DP
TYPE C 1 type C interface
RTC battery RTC battery power interface
Leds Red, Green, Blue
Other IR reciever
Sizes 148 mm × 100.5mm
Weight 100g
Banana Pi BPI-W2 40-pin GPIO
CON1-P02 5VD
CON1-P03 I2C5\_SCL GPIO13
CON1-P04 5VD
CON1-P05 I2C5\_SDA GPIO14
CON1-P07 PWM0\_0 IGPIO21
CON1-P08 UR2\_TX IGPIO3
CON1-P10 UR2\_RX IGPIO2
CON1-P11 GPIO17 GPIO17
CON1-P12 AO\_BCK GPIO58
CON1-P13 I2C3\_SDA GPIO25
CON1-P15 I2C3\_SCL GPIO27
CON1-P16 UR2\_RTS IGPIO5
CON1-P18 UR2\_CTS IGPIO4
CON1-P19 G\_MOSI GPIO7
CON1-P21 G\_MISO GPIO4
CON1-P22 IR\_TX IGPIO9
CON1-P23 G\_SCK GPIO5
CON1-P24 G\_CS GPIO6
CON1-P26 GPIO8 GPIO8
CON1-P27 I2C4\_SDA GPIO12
CON1-P28 I2C4\_SCL GPIO11
CON1-P29 GPIO100 GPIO100
CON1-P31 AI\_CK GPIO21
CON1-P32 SPDIF GPIO54
CON1-P33 AO\_CK GPIO59
CON1-P35 AO\_LRCK GPIO57
CON1-P36 AI\_BCK GPIO22
CON1-P37 AI\_LRCK GPIO23
CON1-P38 AI\_SDO GPIO24
CON1-P40 AO\_D0 GPIO60
BPI-W2 Debug UART(CON3)
CON2-P1 GND
CON2-P2 UART0-RX
CON2-P3 UART0-TX
voltage domain is RGMII.
  • BPI-W2 Realtek 1296 documents download link
google drive :https://drive.google.com/file/d/1PLlU5d0INA2U6Er5unEC7-FpnAmkSh7x/view?usp=sharing
baidu cloud :https://pan.baidu.com/s/1geV5JNl
Android 7.1.1
Android 6.0.1
  • 2018-09-17 update.This release is for banana pi W2 board which is based on realtek RTD1296, and it is based on Ubuntu 18.04 operation system with kernel 4.9.119.
  • Image Link:
W2 Features Map: http://wiki.banana-pi.org/W2_Image_Map
Baidu Drive: https://pan.baidu.com/s/1iLOa1MOgtSqY6dVsQ_SyQg
Google Drive:https://drive.google.com/open?id=1PQO9tA4w_wJvDIz64xJrXzSNS1g4GSlB
  • 2018-09-18 update.This release is for banana pi W2 board which is based on realtek RTD1296, and it is based on Debian 9 operation system with kernel 4.9.119.
  • image Link:
W2 Features Map: http://wiki.banana-pi.org/W2_Image_Map#Debian_9
Baidu Drive:https://pan.baidu.com/s/1bmTektF0ufRL9_FOpdoO2w
Google Drive:https://drive.google.com/open?id=1z1l56qX7BhsD44ha4IGDBhi-_ZqwCjoC
Forum pthread: http://forum.banana-pi.org/t/banana-pi-bpi-w2-new-image-debian-9-linux-image-release-2018-09-18/6797
RPiTC
  • 2018-09-03 update :RPiTCv3_1.12-demo-bpi-w2-beta with Linux kernel 4.9.119
  • image download:
google drive:https://drive.google.com/open?id=1sWjMuKncqDDsb3cGmg22oJs-U2fZjOv0
baidu cloud: https://pan.baidu.com/s/1sd9hoOwyfAxWlGroDMOj4A
more abot RPiTC : http://rpitc.blogspot.com/
Forum pthread:http://forum.banana-pi.org/t/bpi-w2-new-iamge-rpitcv3-1-12-demo-bpi-w2-beta-2018-09-03/6686
  • 1. Now we support to use bpi-copy to burn image to sd card, before this, we need to update our spi rom code, please watch the attachment to update your W2 spi rom code.
  • SPI ROM Tool:
Baidu Drive:https://pan.baidu.com/s/1017nmgw6ZVb5_NgLDz54HQ
Google Drive: https://drive.google.com/open?id=1pq4MDKZi0KhyERB5xNGjTynhFWjXN_jm
  • SPI ROM Image:
Baidu Drive:https://pan.baidu.com/s/1rpfpWK8eoOdPhKwyWoR2Tw
Google Drive: https://drive.google.com/open?id=1Ziz436kDL0kdojECB5bejVd9krzKp0z9
  • How-To Update W2 SPI ROM:
Baidu Drive:https://pan.baidu.com/s/1CZdY_4yFk5r5MSxoog9uOg
Google Drive: https://drive.google.com/open?id=1kXaI5eYJ4cNLnhfr4rTwUVrENbMc1q-E
