Banana Pi BPI-M3
- Allwinner A83T Octa-core 1.8GHz Powerful CPU.
- 2 GB LPDDR3 memory.
- 8 GB eMMC storage.
- HDMI out
- IR control
- WiFi & Bluetooth onboard.
- MIPI DSI ingerface
- CSI camera interface
| Banana Pi BPI-M3 | |
| CPU | Allwinner A83T ARM Cortex-A7 Octa-Core 1.8 GHz, 512KB L1 cache and 1MB L2 cache |
| GPU | PowerVR SGX544MP1 Comply with OpenGL ES 2.0 OpenCL 1x, DX9_3 |
| Memory | 2 GB LPDDR3 (shared with GPU) |
| Storage | On Board 8GB eMMC Flash, Micro SD-Card slot, SATA 2.0 Port (USB-to-SATA bridge) |
| Network | 10/100/1000 Mbit/s Ethernet (Realtek RTL8211E/D) + Wi-Fi 802.11 b/g/n (AP6212) + Bluetooth BT4.0 |
| Video Input(s) | A CSI input connector allows for the connection of a designed camera module |
| Video Output(s) | HDMI 1.4 (Type A Full), MIPI Display Serial Interface (DSI) for raw LCD Panel |
| Audio Input(s) | On board microphone |
| Audio Output(s) | 3.5mm jack and HDMI |
| USB ports | USB 2.0 PORT (x2), USB OTG (x1) |
| Remote | IR Receiver (x1) |
| Switches | Reset, Power and U-boot |
| Size & Weight | 92x60mm, 48g |
| OS | Android and Linux |
| 40 PIN GPIO define of Banana pi BPI-M3 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Default Function| Function2:GPIO| Function3| | -- | | VCC-3V3 | DCIN | TWI2-SDA| PH5-EINT5 | DCIN | TWI2-SCK| PH4-EINT4 | GND | S-PWM| PL10-S-EINT10 | UART2-TX| PB0-EINT0 | GND | UART2-RX| PB1-EINT1 | PC4 PC4 | UART2-CTS| PB3-EINT3 | PC7| PC7 | GND | PC17| PC17 | UART2-RTS| PB2-EINT2 | VCC-3V3 | PL8-ENT8| PL8-S-ENT8 | SPI0_MOSI| PC0 | GND | SPI0_MISO| PC1 | PL9-EINT9| PL9-S-EINT9 | SPI0_CLK| PC2 | SPI0_CS| PC3 | GND | PH10-ENT10| PH10-ENT10 | TWI1-SDA| PH3-EINT3 | TWI1-SCK| PH2-EINT2 | PC18| PC18 | GND | I2S1-BCLK| PG10-EINT10| UART3-TX| | I2S1-DIN| PG13-EINT13| UART3-CTS| | I2S1-LRCK| PG11-EINT11| UART3-RX| | GND | I2S1-DOUT| PG12-EINT12| UART3-RTS| | PE5| PE5 | PE4| PE4 | OWA-DOUT| PE18 | GND | PE19| PE19 | |||||||||||||||||||||||||||||||||||||
- CSI Camera Connector specification:**
CSI Camera Connector:
| CSI camera GPIO of Banana pi BPI-M3 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Default Function| Function2:GPIO| | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| IPSOUT | AFVCC | IPSOUT | IOVDD | GND | GND | CSI2-D3N | AVDD-CSI | CSI2-D3P | DVDD-CSI-R | GND | NC | CSI2-D2N | CSI-RST-R| PE16| | CSI2-D2P | CSI-STBY-R| PE17| | GND | CSI-PCLK| PE0| | CSI2-CKN | CSI-MCLK| PE1| | CSI2-CKP | CSI-HSYNC| PE2| | GND | CSI-VSYNC| PE3| | CSI2-D1N| | CSI-D9| PE13| | CSI2-D1P | CSI-D8| PE12| | GND | CSI-D7| PE11| | CSI2-D0N | CSI-D6| PE10| | CSI2-D0P | CSI-D5| PE9| | GND | CSI-D4| PE8| | CSI-SCK| PE14| | CSI-D3| PE7| | CSI-SDA| PE15| | CSI-D2| PE6| | |||||||||||||||||||||||
- Display specification**
| MIPI DSI PIN define of Banana pi BPI-M3 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Default Function| Function2:GPIO| | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| VCC-MIPI | IPSOUT | VCC-MIPI | IPSOUT | GND | IPSOUT | GND | IPSOUT | NC | GND | NC | DSI-D0N | NC | DSI-D0P | NC | GND | TWI0-SDA| PH1-EINT1| | DSI-D1N | TWI0-SCK| PH0-EINT0| | DSI-D1P | TP-INT| PL7-S-EINT7| | GND | TP-RST| PL6-S-EINT6| | DSI-CKN | GND | DSI-CKP | LCD-BL-EN| PD29| | GND | LCD-RST| PD26| | DSI-D2N | LCD-PWR-EN| PD27| | DSI-D2P | GND | GND | LCD-PWM| PD28| | DSI-D3N | GND | DSI-D3P | AP-RESET# | GND | ||||||||||||||||||||||||||||||||
- UART specification:**
| Uart debug pin of Banana pi BPI-M3 | |||
| Default Function| GPIO| | |||
| UART0-TXD| PB9| | UART0-RXD| PB10| | GND | |
