Getting Started with M2M
BPI-M2M
- 512MB DDR3 SDRAM
* Prepare 8G/above TF card, USB-Serial interface, PC with Ubuntu System * Using your USB-Serial Connect debug console on M2M![]()
Compile code
After download code, execute "./build.sh" to compile it.
- ./build.sh
Update your image
Make your own image
- Execute "bluetoothctl"
- Execute these commands:
NAS Application
1. Usb hub + sata to usb
- HDD is supported
- SSD is supported
We use HDF5640 camara.
BPI-Tools
Install Bpi-tools
Update Bpi-tools
- Execute "bpi-tools"
- cd /usr/local/bin
How to Update WiringPi
