Banana Pi BPI-M2+
Banana PI BPI-M2+ is the open source hardware platform, use Alliwnner H3 (option H2+ H5 ) chip on board. and mini size only 65mm*5mm,
  • Allwinner H3 Quad-core 1.2GHz Cortex-A7 (option H2+ H5).
  • 1GB DDR3
  • 8GB eMMC onboard
  • WiFi and BlueTooth onboard
  • CSI camera interface
HardWare Specification of Banana Pi M2+(Plus)
Flash 8GB eMMC flash onboard
Network 10/100/1000 Ethernet
Audio Outputs HDMI
LED Power led & Status led
IR IR input on board
  • Banana Pi BPI-M2 Zero 40-pin GPIO define is same as BPI-M2+**
Banana Pi BPI-M2 Zero has a 40-pin GPIO header that matches that of the Model 3 Raspberry Pi. Following is the Banana Pi GPIO Pinout:
![](/en/bpi-m2-zero-hardware/gpio define.jpg)
| | GPIO Pin Name | Default Function | Function2:GPIO | Function3 | | :--- | :--- | :--- | :--- | :--- | | | CON2-P01 | VCC-3V3 | | | | | CON2-P02 | VCC-5V | | | | | CON2-P03 | TWI0-SDA | PA12-EINT12 | | | | CON2-P04 | VCC-5V | | | | | CON2-P05 | TWI0-SCK | PA11-EINT11 | | | | CON2-P06 | GND | | | | | CON2-P07 | PWM1 | PA6-EINT6 | | | | CON2-P08 | UART3-TX | PA13-EINT13 | SPI1-CS | | | CON2-P09 | GND | | | | | CON2-P10 | UART3-RX | PA14-EINT14 | SPI1-CLK | | | CON2-P11 | UART2-RX | PA1-EINT1 | | | | CON2-P12 | UART3-CTS | PA16-EINT16 | SPI1-MISO | | | CON2-P13 | UART2-TX | PA0-EINT0 | | | | CON2-P14 | GND | | | | | CON2-P15 | UART2-CTS | PA3-EINT3 | | | | CON2-P16 | UART3-RTS | PA15-EINT15 | SPI1-MOSI | | | CON2-P17 | VCC-3V3 | | | | | CON2-P18 | PC4 | PC4 | | | | CON2-P19 | SPI0-MOSI | PC0 | | | | CON2-P20 | GND | | | | | CON2-P21 | SPI0-MISO | PC1 | | | | CON2-P22 | UART2-RTS | PA2-EINT2 | | | | CON2-P23 | SPI0-CLK | PC2 | | | | CON2-P24 | SPI0-CS | PC3 | | | | CON2-P25 | GND | | | | | CON2-P26 | PC7 | PC7 | | | | CON2-P27 | TWI1-SDA | PA19-EINT19 | | | | CON2-P28 | TWI1-SCK | PA18-EINT18 | | | | CON2-P29 | PA7-EINT7 | PA7-EINT7 | | | | CON2-P30 | GND | | | | | CON2-P31 | PA8-EINT8 | PA8-EINT8 | | | | CON2-P32 | PL2-S-EINT2 | PL2-S-EINT2 | | | | CON2-P33 | PA9-EINT9 | PA9-EINT9 | | | | CON2-P34 | GND | | | | | CON2-P35 | PA10-EINT10 | PA10-EINT10 | | | | CON2-P36 | PL4-S-EINT4 | PL4-S-EINT4 | | | | CON2-P37 | PA17-EINT17 | PA17-EINT17 | SPDIF-OUT | | | CON2-P38 | PA21-EINT21 | PA21-EINT21 | | | | CON2-P39 | GND | | | | CON2-P40 | PA20-EINT20 | PA20-EINT20 | | |
    • CSI Camera Connector specification:**
| | CSI Pin Name | Default Function | Function2:GPIO | | :--- | :--- | :--- | :--- | | | CN3-P01 | NC | | | | CN3-P02 | GND | | | | CN3-P03 | CSI0-SDA | PE13 | | | CN3-P04 | CSI0-AVDD | | | | CN3-P05 | CSI0-SCK | PE12 | | | CN3-P06 | CSI0-Reset | PE14 | | | CN3-P07 | CSI0-VSYNC | PE3 | | | CN3-P08 | CSI0-PWDN | PE15 | | | CN3-P09 | CSI0-HSYNC | PE2 | | | CN3-P10 | CSI0-DVDD | | | | CN3-P11 | CSI0-DOVDD | | | | CN3-P12 | CSI0-D7 | PE11 | | | CN3-P13 | CSI0-MCLK | PE1 | | | CN3-P14 | CSI0-D6 | PE10 | | | CN3-P15 | GND | | | | CN3-P16 | CSI0-D5 | PE9 | | | CN3-P17 | CSI0-PCLK | PE0 | | | CN3-P18 | CSI0-D4 | PE8 | | | CN3-P19 | CSI0-D0 | PE4 | | | CN3-P20 | CSI0-D3 | PE7 | | | CN3-P21 | CSI0-D1 | PE5 | | | CN3-P22 | CSI0-D2 | PE6 | | | CN3-P23 | GND | | | CN3-P24 | CSI0-DOVDD | | |
    • UART specification:**
| | CON3 Pin Name | Default Function | GPIO | | :--- | :--- | :--- | :--- | | | CON3 P03 | UART0-TXD | PA4 | | | CON3 P02 | UART0-RXD | PA5 | | CON3 P01 | GND | | |
Opnewrt
TinaLinux
Release
