Lighting the RGB LED
Revision as of 06:56, 29 August 2018 by Hulkwang (talk | contribs)
How to lighting the RGB LED
Install Library
  1. Install library from github:
  • Librarys:[Adafruit_NeoPixel] from Adafruit
  • Download libraries and put it in the libraries folder in the installation directory of the Arduino IDE
  1. Install Library by Manage Libraries:
Programe Code
  • Open Arduino IDE
click 'file'->'Example'->'Adafruit NeoPixel'->'simple' to open the example
  • We need to change some code,Find the code below in the code
 #define PIN            6
 #define NUMPIXELS      16
  • change to
 #define PIN            4
 #define NUMPIXELS      25
 #define LED_POWER      2
  • Then add the following code to void setup()
  pinMode(LED_POWER, OUTPUT);
  digitalWrite(LED_POWER, HIGH);
  • Compile this program
And download it(Set the serial port and board)
