Banana Pi BPI-M1+
Banana Pi BPI-M1+ upgrade is an open-source single-board computer that adds more connectivity to the classic board. It features the same high performance AllWinner A20 dual-core SoC at 1GHz, 1GB of DDR3 SDRAM, Gigabit Ethernet, SATA, USB, and HDMI connections found in classic BPI-M1+ ; but the Banana Pi M1+ features onboard WiFi g/b/n. The board supports all classic projects and even more because of the onboard WIFi chip. Like its sibling, it can run operating systems including Android, Lubuntu, Ubuntu, Debian, and Raspbian.
The Banana Pi M1+ is our upgraded M1 board. We feel like the onboard WiFi adds a lot more features to the board and makes it more convient for users to set up their linx desktop or router projects. Banana Pi is an open platform device, it is for anyone who wants to play and build with developer technology instead of simply using consumer technology. Backed by our community, starting a project and building servers is fun and rewarding. With a Banana Pi, we want you to explore and experience the world of DIY projects and portable computing. We welcome all companies, DIYers, and tech loving people within our community! Together, we can make a difference, we can discover our passions, inspire others, and build a practical project.
- 1 GB DDR3 memory.
- Wifi &BT support onboard
- 1x SATA interface.
- 1x Gigabit LAN
- 1x USB otg and 2x USB 2.0
- 1X MIC
- AV out
- HDMI out
- IR
- CSI camera interface
- DSI display interface
- 40 PIN gpio
| Banana Pi M1+ | |
| CPU | A20 ARM Cortex -A7 Dual-Core |
| GPU | ARM Mali400MP2Complies with OpenGL ES 2.0/1.1 |
| Memory | 1GB DDR3 |
| Network | 10/100/1000 Ethernet |
| wifi&BT | Wifi & BT 4.0 support onboard |
| Video Input | A CSI input connector allows for the connection of a designed camera module |
| Video Outputs | HDMI, CVBS, LVDS/RGB |
| Audio Outputs | 3.5mm jack and HDMI |
| Power Source | 5V/2A via Micro USB (DC in only) and / or Micro USB OTG |
| USB 2.0 ports | 2(direct from Allwinner A20 chip) |
| GPIO | GPIO, UART, I2C BUS, SPI BUS, WITH TWO CHIP SELECTS, CAN bus, ADC, PWM, +3.3V, +5V, GND |
| LED | Power Key & 8P8C |
| Storage | SATA 2.0 |
| OS | Android 4.4, Android 4.2, Raspbian, Lubuntu, Open Suse, Debian |
| 40 PIN GPIO of Banana pi BPI-M1+ | |||
| GPIO Pin Name | Default Function | Function2:GPIO | |
| CON3-P01 | VCC-3V3 | ||
| CON3-P02 | VCC-DC | ||
| CON3-P03 | TWI2-SDA | PB21 | |
| CON3-P04 | VCC-DC | ||
| CON3-P05 | TWI2-SCK | PB20 | |
| CON3-P06 | GND | ||
| CON3-P07 | PWM1 | PI3 | |
| CON3-P08 | UART3\_TX | PH0 | |
| CON3-P09 | GND | ||
| CON3-P10 | UART3\_RX | PH1 | |
| CON3-P11 | UART2\_RX | PI19 | |
| CON3-P12 | PH2 | PH2 | |
| CON3-P13 | UART2\_TX | PI18 | |
| CON3-P14 | GND | ||
| CON3-P15 | UART2\_CTS | PI17 | |
| CON3-P16 | CAN\_TX | PH20 | |
| CON3-P17 | VCC-3V3 | ||
| CON3-P18 | CAN\_RX | PH21 | |
| CON3-P19 | SPI0\_MOSI | PI12 | |
| CON3-P20 | GND | ||
| CON3-P21 | SPI0\_MISO | PI13 | |
| CON3-P22 | UART2\_RTS | PI16 | |
| CON3-P23 | SPI0\_CLK | PI11 | |
| CON3-P24 | SPI0\_CS0 | PI10 | |
| CON3-P25 | GND | ||
| CON3-P26 | SPI0\_CS1 | PI14 | |
| CON3-P27 | TWI3-SDA | PI1 | |
| CON3-P28 | TWI3-SCK | PI0 | |
| CON3-P29 | I2S\_MCLK | PB5 | |
| CON3-P30 | GND | ||
| CON3-P31 | I2S\_BCLK | PB6 | |
| CON3-P32 | I2S\_DI | PB12 | |
| CON3-P33 | I2S\_LRCK | PB7 | |
| CON3-P34 | GND | ||
| CON3-P35 | I2S\_DO0 | PB8 | |
| CON3-P36 | UART7\_RX | PI21 | |
| CON3-P37 | IR0\_TX | PB3 | |
| CON3-P38 | UART7\_TX | PI20 | |
| CON3-P39 | GND | ||
| CON3-P40 | SPDIF\_DO | PB13 | |
| CSI PIN of Banana pi BPI-M1+ | |||
| CSI Pin Name | Default Function Pin name | Function2:GPIO | |
| CON1 P01 | LINEINL | ||
| CON1 P02 | LINEINR | ||
| CON1 P03 | VCC-CSI | ||
| CON1 P04 | ADC\_X1 | ||
| CON1 P05 | GND | ||
| CON1 P06 | ADC\_X2 | ||
| CON1 P07 | FMINL | ||
| CON1 P08 | ADC\_Y1 | ||
| CON1 P09 | FMINR | ||
| CON1 P10 | ADC\_Y2 | ||
| CON1 P11 | GND | ||
| CON1 P12 | CSI-FLASH | PH17 | |
| CON1 P13 | LRADC0 | ||
| CON1 P14 | TWI1-SDA | PB19 | |
| CON1 P15 | LRADC1 | ||
| CON1 P16 | TWI1-SCK | PB18 | |
| CON1 P17 | CSI-D0 | PE4 | |
| CON1 P18 | CSI0-STBY-EN | PH19 | |
| CON1 P19 | CSI0-D1 | PE5 | |
| CON1 P20 | CSI-PCLK | PE0 | |
| CON1 P21 | CSI-D2 | PE6 | |
| CON1 P22 | CSI0-PWR-EN | PH16 | |
| CON1 P23 | CSI-D3 | PE7 | |
| CON1 P24 | CSI0-MCLK | PE1 | |
| CON1 P25 | CSI-D4 | PE8 | |
| CON1 P26 | CSI0-RESET\# | PH14 | |
| CON1 P27 | CSI-D5 | PE9 | |
| CON1 P28 | CSI-VSYNC | PE3 | |
| CON1 P29 | CSI-D6 | PE10 | |
| CON1 P30 | CSI-HSYNC | PE2 | |
| CON1 P31 | CSI-D7 | PE11 | |
| CON1 P32 | CSI1-STBY-EN | PH18 | |
| CON1 P33 | AP-RESET\# | ||
| CON1 P34 | CSI1-RESET\# | PH13 | |
| CON1 P35 | CSI-IO0 | PH11 | |
| CON1 P36 | HPR | ||
| CON1 P37 | HPL | ||
| CON1 P38 | IPSOUT | ||
| CON1 P39 | GND | ||
| CON1 P40 | IPSOUT | ||
| LVDS PIN of Banana pi BPI-M1+ | ||||||||||||||||||||||||||||||||||||||||
| Default Function | Function2 | Function3:GPIO | | IPSOUT\(5V output\) | | | | TWI3-SDA | | PI1 | | IPSOUT\(5V output\) | | | | TWI3-SCK | | PI0 | | GND | | | | LCD0-IO0 | | PH7 | | LCDIO-03 | | PH12 | | LCD0-IO1 | | PH8 | | LCD0-D0 | LVDS0-VP0 | PD0 | | PWM0 | | PB2 | | LCD0-D1 | LVDS0-VN0 | PD1 | | LCD0-IO2 | | PH9 | | LCD0-D2 | LVDS0-VP1 | PD2 | | LCD0-DE | | PD25 | | LCD0-D3 | LVDS0-VN1 | PD3 | | LCD0-VSYNC | | PD27 | | LCD0-D4 | LVDS0-VP2 | PD4 | | LCD0-HSYNC | | PD26 | | LCD0-D5 | LVDS0-VN2 | PD5 | | LCD0-CS | | PH6 | | LCD0-D6 | LVDS0-VPC | PD6 | | LCD0-CLK | | PD24 | | LCD0-D7 | LVDS0-VNC | PD7 | | GND | | | | LCD0-D8 | LVDS0-VP3 | PD8 | | LCD0-D23 | | PD23 | | LCD0-D9 | LVDS0-VN3 | PD9 | | LCD0-D22 | | PD22 | | LCD0-D10 | | PD10 | | LCD0-D21 | | PD21 | | LCD0-D11 | | PD11 | | LCD0-D20 | | PD20 | | LCD0-D12 | | PD12 | | LCD0-D19 | | PD19 | | LCD0-D13 | | PD13 | | LCD0-D18 | | PD18 | | LCD0-D14 | | PD14 | | LCD0-D17 | | PD17 | | LCD0-D15 | | PD15 | | LCD0-D16 | | PD16 | |
- UART specification:**
| style | Pin Name | Default Function | GPIO | | :--- | :--- | :--- | | CON4 P03 | UART0-TXD | PB22 | | CON4 P02 | UART0-RXD | PB23 | | GND | | | |
