Description
The BPI-9600 series of modules are designed to extract power from a conventional twisted pair Category 5 Ethernet cable, conforming to the IEEE 802.3af Power-over-Ethernet(PoE) standard. The BPI-9600 signature and control circuit provides the PoE compatibility signature and power classification required by the Power Sourcing Equipment (PSE) before applying up to 15W power to the port. The BPI-9600 provides a Class 0 signature.
The DC/DC converter operates over a wide input voltage range and provides a regulated output. The DC/DC converter also has built-in short-circuit output protection.
Features
- IEEE802.3af compliant
- Low output ripple and noise
- Short-circuit protection
- Adjustable Output
Applications
- IoT gateway
- IP Cameras
- Wireless access point
- Security and alarm systems
- VOIP telephone
PBI-9600 PoE module size
Product Selector
| BPI-9600 PoE module | ||||
| Part Number | Nominal Output Voltage | Maximum Output Power | Marking | Package |
| BPI-9600-3.3V | 3.3V | 6.6W | 3.3V | SIL |
| BPI-9600 -5V | 5V | 10W | 5V | SIL |
| BPI-9600 -12V | 12V | 12W | 12V | SIL |
| BPI-9600 -24V | 24V | 12W | 24V | SIL |
