Banana Pi BPI-ZERO
- 512MB DDR 3 SDRAM.
- Mini HDMI.
| HardWare Specification of Banana pi BPI-M2 zero VS Raspberry Pi Zero W | |||
| Module | Banana Pi BPI-M2 Zero | Raspberry Pi Zero W | |
| CPU | H2+ Quad-core Cortex-A7 H265/HEVC 1080P | Broadcom BCM2835 32 Bit 1 GHz ARM1176JZF-S single-core | |
| GPU | Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0 | VideoCore IV | |
| Memory \(SDRAM\) | 512M DDR3(shared with GPU) | 512 MB DDR2 | |
| Onboard Storage | TF card \(Max. 64GB\) | TF card \(Max. 64GB\) | |
| Onboard Network | NOPE (but can extension with PIN define) | NOPE | |
| Onboard WIFI | SDIO AP6212(option AP6181、AP6335) | 802.11n wireless, Bluetooth 4.1 | |
| Video decoding | 1080p@60fps,H.264 Video encoding 1080p@30fps,H.264 | 1080p30 H.264/MPEG-4 AVC high-profile decoder and encoder | |
| Video input | A CSI input connector Camera | CSI camera connector | |
| Video Outputs | mini HDMI 1.4,1080P@30fps, DHCP | Mini HDMI and USB On-The-Go ports | |
| Audio Output | Mini HDMI | Mini HDMI | |
| Power Source | Micro USB with 5V/2A | 5V/2A | |
| USB 2.0 Ports | one USB 2.0 OTG | one USB 2.0 OTG | |
| Buttons | Power Button, Reset Button | Composite video and reset headers | |
| Low-level peripherals | 40 Pins Header,compatible with Raspberry Pi 3 | 40 PIN | |
| uart GPIO\(1x3\) pin | UART, ground | UART | |
| LED | Power led & Status led | Power Status LED | |
| IR | N/A | N/A | |
| Supported OS | Android, Ubuntu, Debian, Rasberry Pi Image | Linux | |
| Product size | 65mm × 30mm | 65mm x 30mm | |
| Weight | 15g | 9G | |
| 40 PIN GPIO of Banana pi BPI-M2 zero | |||
| CON2-P01 | VCC-3V3 | ||
| CON2-P02 | VCC-5V | ||
| CON2-P04 | VCC-5V | ||
| CON2-P06 | GND | ||
| CON2-P09 | GND | ||
| CON2-P14 | GND | ||
| CON2-P17 | VCC-3V3 | ||
| CON2-P18 | PC4 | PC4 | |
| CON2-P20 | GND | ||
| CON2-P25 | GND | ||
| CON2-P26 | PC7 | PC7 | |
| CON2-P30 | GND | ||
| CON2-P34 | GND | ||
| CON2-P39 | GND | ||
| 24 PIN CSI Camera connector of Banana pi BPI-M2 Zero | |||
| CN3-P01 | NC | ||
| CN3-P02 | GND | ||
| CN3-P04 | CSI0-AVDD | ||
| CN3-P10 | CSI0-DVDD | ||
| CN3-P11 | CSI0-DOVDD | ||
| CN3-P15 | GND | ||
| CN3-P16 | CSI0-D5 | PE9 | |
| CN3-P18 | CSI0-D4 | PE8 | |
| CN3-P19 | CSI0-D0 | PE4 | |
| CN3-P20 | CSI0-D3 | PE7 | |
| CN3-P21 | CSI0-D1 | PE5 | |
| CN3-P22 | CSI0-D2 | PE6 | |
| CN3-P23 | GND | ||
| CN3-P24 | CSI0-DOVDD | ||
| jumper CON3 of Banana pi BPI-M2 Zero | |||
| CON3 P01 | GND | ||
PIN define:
schematic diagram:
test
Zero power with GPIO 5V input
- Allwinner documents:
- Android 4.4 source code
- Linux source code
Android 4.4
2018-07-09 update Android 4.4
2017-11-12 update Android 4.4
- Forum pthread:
- Image Link:
- Forum thread:
RetroPie
retrorangepi
Raspbian 8.0
2018-07-09
- Image Link:
- Google Drive: https://drive.google.com/file/d/1XMVCWCWoWmhzL-c89rkqzZVE_k7xYCvd/view
- baidu Drive: https://pan.baidu.com/s/1ahXv3Hl7Dst7uBwz60pcrg 2
- Forum thread:
Ubuntu 16.04 mate desktop
2018-07-09
- Image Link:
- Forum thread:
2017-11-13
- Image Link:
- Forum thread:
