Banana Pi BPI-P2 Zero
Banana Pi BPI-F2 Zero is an ultra compact single board computer measures only 65mm*52.5mm. It uses quad-core Cortex A7 allwinner H2+ processor(Option : H3 and H5), with 512MB RAM memory.8G eMMC flash,100M LAN,add PoE function support , It's ideal for light-weight systems with some space-limited applications. Like other members of Banana Pi, it supports both linux and android operating system.
- 512MB DDR 3 SDRAM.
- Mini HDMI.
- 100M LAN
- PoE function support
- 8G eMMC flash onboard.
HardWare Specification of Banana pi BPI-M2 zero VS Raspberry Pi Zero W | |||
Module | Banana Pi BPI-M2 Zero | Raspberry Pi Zero W | |
CPU | H2+ Quad-core Cortex-A7 H265/HEVC 1080P | Broadcom BCM2835 32 Bit 1 GHz ARM1176JZF-S single-core | |
GPU | Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0 | VideoCore IV | |
Memory \(SDRAM\) | 512M DDR3(shared with GPU) | 512 MB DDR2 | |
Onboard Storage | TF card \(Max. 64GB\) | TF card \(Max. 64GB\) | |
Onboard Network | NOPE (but can extension with PIN define) | NOPE | |
Onboard WIFI | SDIO AP6212(option AP6181、AP6335) | 802.11n wireless, Bluetooth 4.1 | |
Video decoding | 1080p@60fps,H.264 Video encoding 1080p@30fps,H.264 | 1080p30 H.264/MPEG-4 AVC high-profile decoder and encoder | |
Video input | A CSI input connector Camera | CSI camera connector | |
Video Outputs | mini HDMI 1.4,1080P@30fps, DHCP | Mini HDMI and USB On-The-Go ports | |
Audio Output | Mini HDMI | Mini HDMI | |
Power Source | Micro USB with 5V/2A | 5V/2A | |
USB 2.0 Ports | one USB 2.0 OTG | one USB 2.0 OTG | |
Buttons | Power Button, Reset Button | Composite video and reset headers | |
Low-level peripherals | 40 Pins Header,compatible with Raspberry Pi 3 | 40 PIN | |
uart GPIO\(1x3\) pin | UART, ground | UART | |
LED | Power led & Status led | Power Status LED | |
IR | N/A | N/A | |
Supported OS | Android, Ubuntu, Debian, Rasberry Pi Image | Linux | |
Product size | 65mm × 30mm | 65mm x 30mm | |
Weight | 15g | 9G |
