Banana Pi BPI-M2M
  • Allwinner R16/A33 Quad Core ARM Cortex A7 CPU.
  • 512MB DDR3 SDRAM.
  • 8G eMMC flash
  • CSI camera interface
  • DSI display interface
Banana Pi M2 Magic
CPU Allwinner R16 ARM Cortex-A7 Quad-Core
Memory 512MB LPDDR3 (shared with GPU)
Storage On Board 8GB eMMC Flash, Micro SD-Card slot.
Network Wi-Fi 802.11 b/g/n (AP6212) + Bluetooth BT4.0
Video Output(s) MIPI Display Serial Interface (DSI) for raw LCD Panel
Audio Output(s) 3.5mm jack
USB ports USB 2.0 PORT (x1), USB OTG (x1)
Remote Not IR Receiver
LED Power Status and 8P8C
Size & Weight 51x51mm, 48g
OS Android and Linux
| | **Default Function** | **Function2:GPIO** | | :--- | :--- | :--- | | CON1-P01 | VCC-3V3 | | | CON1-P02 | DCIN | | | CON1-P03 | TWI1-SDA | PH5 | | CON1-P04 | DCIN | | | CON1-P05 | TWI1-SCK | PH4 | | CON1-P06 | GND | | | CON1-P07 | PWM1 | PH1 | | CON1-P08 | UART2-TX | PB0 | | CON1-P09 | GND | | | CON1-P10 | UART2-RX | PB1 | | CON1-P11 | UART3\_TX | PH6 | | CON1-P12 | UART2-CTS | PB3 | | CON1-P13 | UART3\_RX | PH7 | | CON1-P14 | GND | | | CON1-P15 | AP-PCM-DOUT | PG12 | | CON1-P16 | UART2-RTS | PB2 | | CON1-P17 | VCC-3V3 | | | CON1-P18 | AP-PCM-CLK | PG11 | | CON1-P19 | SPI0\_MOSI | PC0 | | CON1-P20 | GND | | | CON1-P21 | SPI0\_MISO | PC1 | | CON1-P22 | AP-PCM-SYNC | PG10 | | CON1-P23 | SPI0\_CLK | PC2 | | CON1-P24 | SPI0\_CS | PC3 | | CON1-P25 | GND | | | CON1-P26 | AP-PCM-DIN | PG13 | | CON1-P27 | LVDS\_V0N | PD19 | | CON1-P28 | PL11-EINT11 | PL11 | | CON1-P29 | LVDS\_V0P | PD18 | | CON1-P30 | GND | | | CON1-P31 | LVDS\_V1N | PD21 | | CON1-P32 | LVDS\_V2N | PD23 | | CON1-P33 | LVDS\_V1P | PD20 | | CON1-P34 | GND | | | CON1-P35 | LVDS\_VCN | PD25 | | CON1-P36 | LVDS\_V2P | PD22 | | CON1-P37 | LVDS\_VCP | PD24 | | CON1-P38 | LVDS\_V3N | PD27 | | CON1-P39 | GND | | | CON1-P40 | LVDS\_V3P | PD26 |
    • CSI Camera Connector specification:**
    • CSI Pin Name**
| | **Default Function** | **Function2:GPIO** | | :--- | :--- | :--- | | CN3-P01 | NC | | | CN3-P02 | GND | | | CN3-P03 | CSI0-SDA | PE13 | | CN3-P04 | CSI0-AVDD | | | CN3-P05 | CSI0-SCK | PE12 | | CN3-P06 | CSI0-Reset | PE14 | | CN3-P07 | CSI0-VSYNC | PE3 | | CN3-P08 | CSI0-PWDN | PE15 | | CN3-P09 | CSI0-HSYNC | PE2 | | CN3-P10 | CSI0-DVDD | | | CN3-P11 | CSI0-DOVDD | | | CN3-P12 | CSI0-D7 | PE11 | | CN3-P13 | CSI0-MCLK | PE1 | | CN3-P14 | CSI0-D6 | PE10 | | CN3-P15 | GND | | | CN3-P16 | CSI0-D5 | PE9 | | CN3-P17 | CSI0-PCLK | PE0 | | CN3-P18 | CSI0-D4 | PE8 | | CN3-P19 | CSI0-D0 | PE4 | | CN3-P20 | CSI0-D3 | PE7 | | CN3-P21 | CSI0-D1 | PE5 | | CN3-P22 | CSI0-D2 | PE6 | | CN3-P23 | GND | | | CN3-P24 | CSI0-AFVCC | |
    • Display specification**
    • DSI Pin Name**
| | **Default Function** | **Function2:GPIO** | | :--- | :--- | :--- | | CN2-P01 | DSI-D0N | | | CN2-P02 | DSI-D0P | | | CN2-P03 | DSI-D1N | | | CN2-P04 | DSI-D1P | | | CN2-P05 | DSI-CKN | | | CN2-P06 | DSI-CKP | | | CN2-P07 | DSI-D2N | | | CN2-P08 | DSI-D2P | | | CN2-P09 | DSI-D3N | | | CN2-P10 | DSI-D3P | | | CN2-P11 | NC | | | CN2-P12 | NC | | | CN2-P13 | TP-SDA | PH3 | | CN2-P14 | TP-SCK | PH2 | | CN2-P15 | TP-INT | PB5 | | CN2-P16 | TP-RST | PB6 | | CN2-P17 | LCD-BL-EN | PL4 | | CN2-P18 | LCD-RST | PL5 | | CN2-P19 | LCD-PWR-EN | PB7 | | CN2-P20 | LCD-PWM | PH0 | | CN2-P21 | GND | | | CN2-P22 | GND | | | CN2-P23 | PS | | | CN2-P24 | PS | |
    • UART specification:
| CON3-P1 | GND | | | :--- | :--- | :--- | | CON3-P2 | UART0-RX | | | CON3-P3 | UART0-TX | |
Opnewrt
TinaLinux
Release
