Banana Pi BPI-M2+
Banana PI BPI-M2+ is the open source hardware platform,BPI-M2+ is an quad core version of Banana Pi,it support WIFI on board. use Alliwnner H3 (option H2+ H5 ) chip on board. and mini size only 65mm*5mm,
- Allwinner H3 Quad-core 1.2GHz Cortex-A7 (option H2+ H5).
- 1GB DDR3
- 8GB eMMC onboard
- WiFi and BlueTooth onboard
- CSI camera interface
| HardWare Specification of Banana Pi M2+(Plus) | ||||
| CPU | H3 Quad-core Cortex-A7 H.265/HEVC 4K | |||
| GPU | Mali400MP2 GPU @600 MHz,Supports OpenGL ES 2.0 | |||
| Memory | 1GB DDR3 (shared with GPU) | |||
| Flash | 8GB eMMC flash onboard | |||
| Network | 10/100/1000 Ethernet | |||
| WIFI&BT | SDIO AP6212 for Wifi &BT 4.0(option AP6181 AP6335) | |||
| Video Input | A CSI input connector Camera:1 Supports 8-bit YUV422 CMOS sensor interface,2 Supports CCIR656 protocol for NTSC and PAL, 3 Supports SM pixel camera sensor, 4 Supports video capture solution up to 1080p@30fps | |||
| Video Outputs | Supports HDMI output with HDCP, Supports HDMI CEC, Supports HDMI 30 function, Integrated CVBS, Supports simultaneous output of HDMI and CVBS | |||
| Audio Outputs | HDMI | |||
| Power | 5V/2A DC input can supply power, but USB OTG input don’t supply power | |||
| USB 2.0 ports | two USB 2.0 HOST, one USB 2.0 OTG | |||
| GPIO | 40 Pins Header,compatible with Raspberry Pi B+ | |||
| LED | Power led & Status led | |||
| IR | IR input on board | |||
| OS | Android, Ubuntu, Debian, Raspberry Pi Image | |||
Opnewrt
TinaLinux
