Banana Pi BPI-M2+
- Allwinner H3 Quad-core 1.2GHz Cortex-A7 (option H2+ H5).
- 1GB DDR3
- 8GB eMMC onboard
- HDMI out
- WiFi and BlueTooth onboard
- CSI camera interface
| HardWare Specification of Banana Pi M2+(Plus) | ||||
| CPU | H3 Quad-core Cortex-A7 H.265/HEVC 4K | |||
| GPU | Mali400MP2 GPU @600 MHz,Supports OpenGL ES 2.0 | |||
| Memory | 1GB DDR3 (shared with GPU) | |||
| Flash | 8GB eMMC flash onboard | |||
| Network | 10/100/1000 Ethernet | |||
| WIFI&BT | SDIO AP6212 for Wifi &BT 4.0(option AP6181 AP6335) | |||
| Video Input | A CSI input connector Camera:1 Supports 8-bit YUV422 CMOS sensor interface,2 Supports CCIR656 protocol for NTSC and PAL, 3 Supports SM pixel camera sensor, 4 Supports video capture solution up to 1080p@30fps | |||
| Video Outputs | Supports HDMI output with HDCP, Supports HDMI CEC, Supports HDMI 30 function, Integrated CVBS, Supports simultaneous output of HDMI and CVBS | |||
| Audio Outputs | HDMI | |||
| Power | 5V/2A DC input can supply power, but USB OTG input don’t supply power | |||
| USB 2.0 ports | two USB 2.0 HOST, one USB 2.0 OTG | |||
| GPIO | 40 Pins Header,compatible with Raspberry Pi B+ | |||
| LED | Power led & Status led | |||
| IR | IR input on board | |||
| OS | Android, Ubuntu, Debian, Raspberry Pi Image | |||
| 40 PIN GPIO of Banana pi BPI-M2+ | |||
| CON2-P01 | VCC-3V3 | ||
| CON2-P02 | VCC-5V | ||
| CON2-P04 | VCC-5V | ||
| CON2-P06 | GND | ||
| CON2-P09 | GND | ||
| CON2-P14 | GND | ||
| CON2-P17 | VCC-3V3 | ||
| CON2-P18 | PC4 | PC4 | |
| CON2-P20 | GND | ||
| CON2-P25 | GND | ||
| CON2-P26 | PC7 | PC7 | |
| CON2-P30 | GND | ||
| CON2-P34 | GND | ||
| CON2-P39 | GND | ||
| CSI Camera PIN of Banana pi BPI-M2+ | |||
| CN3-P01 | NC | ||
| CN3-P02 | GND | ||
| CN3-P04 | CSI0-AVDD | ||
| CN3-P10 | CSI0-DVDD | ||
| CN3-P11 | CSI0-DOVDD | ||
| CN3-P15 | GND | ||
| CN3-P16 | CSI0-D5 | PE9 | |
| CN3-P18 | CSI0-D4 | PE8 | |
| CN3-P19 | CSI0-D0 | PE4 | |
| CN3-P20 | CSI0-D3 | PE7 | |
| CN3-P21 | CSI0-D1 | PE5 | |
| CN3-P22 | CSI0-D2 | PE6 | |
| CN3-P23 | GND | ||
| CN3-P24 | CSI0-DOVDD | ||
| Uart PIN of Banana pi BPI-M2+ | |||
| CON3 P01 | GND | ||
Hardware V1.2 Version
BPi-M2+ V1.2 modification
- 1,PL0 Instead the drop-down 10K,As a hardware version identification(V1.1 is pull up)
- 2,PL1 Change to voltage regulation GPIO
- BPI-M2+ V1.2 schematic diagram
- BPI-M2+ V1.1 schematic diagram: https://drive.google.com/file/d/0B4PAo2nW2KfnMW5sVkxWSW9qa28/view?usp=sharing
- DXF file google download link :BPI-M2+ DXF file
- 3D design file google download link: BPI-M2+ 3D design
- BPI-M2+ BT Lab test :BPI-M2+ BT Lab test report
- BPI-M2+ WIFI Lab test :BPI-M2+ WIFI Lab test report
- Validation test :BPI-M2+ validation test report
- CE FCC RoHS : BPI-M2+ CE,FCC,RoHS
- Allwinner documents:
- Banana Pi M2 Plus - Unboxing e apresentação da placa.: https://www.youtube.com/watch?v=_87uHfyMIUA&feature=youtu.be
Android 7.0
- Image Link:
- Google Drive : https://drive.google.com/file/d/1TY4CgFxCT3pR6S2nw5w-_XkNsW9fPBhI
- Baidu Drive : https://pan.baidu.com/s/1ETpbauIezp1228n7kdWo4A
- Forum thread: http://forum.banana-pi.org/t/bananapi-bpi-m2p-h3-new-image-android7-0-release-2018-6-30/6147
- How to Google registration: https://www.google.com/android/uncertified/ Android7.0 needs to register devices by youself
Android 4.4
- Image Link:
- Google Drive: https://drive.google.com/open?id=0B_YnvHgh2rwjOWg4ZzBnR0VieFU
- Baidu Drive: https://pan.baidu.com/s/1gfr7vJ9
- Forum thread: http://forum.banana-pi.org/t/bpi-m2-new-image-android-4-4-version-v3/2765
Rasbian Linux
Kernel 3.4
- 2018-5-22 update : Raspbian jessie 8.0
- Image Link:
- Source Code Github Repo: https://github.com/BPI-SINOVOIP/BPI-M2P-bsp
- Forum thread:
- http://forum.banana-pi.org/t/banana-pi-bpi-m2p-new-image-release-raspbian-jessie-8-0-2018-5-22/5788
Kernel 3.4
- 2018-5-17 update : Ubuntu 16.04 V1.1 new eMMC and PMU support
- Image Link:
- Forum thread:
- 2017-07-14 update : ubuntu-16.04-mate-desktop
- Image Link:
- Google Drive: Google Drive: https://drive.google.com/open?id=1dlfo9LGNcrc-_cpKd1uJnrNx0PdonBnK
- baidu cloud : http://pan.baidu.com/s/1dEX2TDR
- Forum thread:
- Image Link:
Kernel 4.4
- 2018-01-02 update : Ubuntu image with Kernel 4.4.55
Armbian image
- Armbian 5.51 debin Bananapi-m2+ build by BPI 2018-07-12
- armbin image download: https://www.armbian.com/banana-pi-m2-plus/
Openelec Kodi
- Openelec Kodi 16.0 (xbmc)
- file name:http:OpenELEC-H3.arm-7.0-devel-20161026220508-r23113-g64b34b3-bpim2p.img.gz
- download link: http://down.nu/images/2016-10-26
- baidu cloud:http://pan.baidu.com/s/1mhMTEnI
- forum pthread:http://forum.banana-pi.org/t/openelec-kodi-16-0-xbmc-on-the-banana-pi-bpi-m2-project/1600
Raspbian
- 2018-5-22 update : Raspbian 8.0 V1.1 new eMMC and PMU
- Image Link:
- Google Drive: https://drive.google.com/open?id=1-jQNZrJQi_KajZre6c6mbt5bHilF0h1x
- baidu cloud : https://pan.baidu.com/s/16KJbtwjT_PBCZJkYV79_ag
- Forum thread:
- Image Link:
FreeBSD
Lakka TV
- Banana Pi M2+ with H3 chip
- Banana Pi M3 with A83T chip
Dietpi
- Dietpi have official support BPI-M2+ : http://forum.banana-pi.org/t/dietpi-have-official-support-bpi-m2/1882
RetroPie
- RetroPie for Banana Pi BPI-M2+/M2 Zero v.1.2.1 beta
Others image
- others image download link : http://forum.banana-pi.org/c/Banana-pi-BPI-M2/M2image
