Banana Pi BPI-M2+
  • Allwinner H3 Quad-core 1.2GHz Cortex-A7
  • 1GB DDR3
  • 8GB eMMC onboard
  • WiFi and BlueTooth onboard
  • CSI camera interface
HardWare Specification of Banana Pi M2+(Plus)
Flash 8GB eMMC flash onboard
Network 10/100/1000 Ethernet
Onboard WIFI SDIO AP6212(option AP6181 AP6335)
Audio Outputs HDMI
LED Power led & Status led
IR IR input on board
Opnewrt
TinaLinux
Release
